Old 08-01-2012, 05:09 PM   #1
davepl
davepl's Avatar
BBC - Which exhaust bolts are which?
Finally found something I didn't take a good photo of - the layout of the passenger side exhaust manifold bolts.
I know probably two of them are double-ended bolts for retaining the AC bracket, but I only have one left at this point.
If someone has a 396/402 with air, I'd sure appreciate it if they could tell me the layout of the bolts (both sides, in case I've used one too many on the driver's side).
Thanks!
Dave
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-01-2012, 05:36 PM   #2
burb71
Active Member
Re: BBC - Which exhaust bolts are which?
Just looked at my motor, the forward most bolt on both sides driver and pass side are double ended for brackets.
Pass side A/C bracket, drivers side power steering pump
burb71 is offline   Reply With Quote
Old 08-01-2012, 07:37 PM   #3
davepl
davepl's Avatar
Thanks! In the photo below I've highlighted a bar that goes from the back of the AC compressor down to what I assume are the manifold bolts.
Do the manifold bolts just go right through the bracket, as opposed to being double-ended with a nut?
That's sort of how it looks, but I didn't think the factory did stuff like that (added options that required disturbing the manifold bolts).
Thanks!
Dave
Old 08-01-2012, 08:16 PM   #4
burb71
Active Member
Remember its the very first bolt, its the one ahead of the one in your pic, at least on my truck.
