Old 08-01-2012, 05:52 PM   #1
oldusafmsgt
oldusafmsgt's Avatar
1963 - 3/4 speed Trans Crossmember Removal
I need to remove the factory 3/4 speed trans frame crossmember from a 63. Looks like it's held in with about 6 rivets that possibly were salvaged from the Titanic. I'm converting to a factory column shift Powerglide, was a floor shift when I got the truck. I have the aftermarket trans crossmember under the rear of the glide, so I'm assuming I can remove the stick crossmember without losing any strength integrity. I also have accumulated all the correct linkage. Anyone know the best/easiest way to remove this crossmember ?
Greg
1960 Chevy Apache10 Short Fleetside
1961 Chevy Apache10 Short Fleetside
1961 Chevy Apache20 Fleetside
1963 Chevy C10 Short Fleetside
1965 Chevy C10 Short Stepside
1965 Chevy C10 Long Fleetside
1966 GMC 1000 Long Fleetside
1966 Chevy C10 Short Fleetside
oldusafmsgt is offline   Reply With Quote
Old 08-01-2012, 09:30 PM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: 1963 - 3/4 speed Trans Crossmember Removal
on my wifes truck, since I didn't want to deal with the rivets, I just went after it with a sawazall...
I just busted a bunch of rivets off a frame, and the best method I came up with (after a few searches on here) was to "X" cut the head of the rivet with a grinder/cutoff wheel, bust what was left off with a chisel, and push it through with a punch, and if it didn't push through with a punch, grind it smooth, and then push it through with a punch.
a couple of them were real tough, so I drilled into them with a 3/16 bit, and then pushed them through with a punch.
it is going to be real tough to access 2 of the rivets, because they are right under the floorboard.
Old 08-01-2012, 09:59 PM   #3
rbar
rbar's Avatar
I also x cut mine and ground. I sawed it in half also to not fight trying to twist it out.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 08-01-2012, 10:29 PM   #4
oldusafmsgt
Thanks guys, I'm trying to do it with the cab on. I have a plasma cutter, but not much room to get the torch in there. So a cutoff wheel and sawzall it is !
Old 08-01-2012, 10:39 PM   #5
padresag
taking the easy way out
ron
padresag is offline   Reply With Quote
