Old 08-01-2012, 08:44 PM   #1
SRVBLUES64
brake booster questions
I have a 66 chevy c10 and Im heading to pic a part saturday to look for two things a power booster and a set of seat belts I believe I have shoulder bolts can anyone tell me what trucks I can pull these prts from???? Thanks
SRVBLUES64 is offline   Reply With Quote
Old 08-01-2012, 09:07 PM   #2
Larry64
Re: brake booster questions
I got mine out of a 1994 S-10 Blazer. The seat belts that is.
Larry
Larry64 is offline   Reply With Quote
Old 08-01-2012, 10:03 PM   #3
rbar
rbar's Avatar
I got a factory power booster from ebay. ended up having to rebuild the master cylinder. found out that autozone had a replacement set for $150. other than factory correct I would have saved money to just buy it new.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 08-01-2012, 10:32 PM   #4
jocko
jocko's Avatar
are you retaining 4-wheel drums or planning to upgrade to any disks?
if planning om 4 wheel drums, I'd go with a 67 C10 dual res master and booster combo (make sure to buy them together to ensure you are buying a power master cylinder, there is a difference (shallow hole in power/deep hole in non-power mc piston) (or, if maintaining 4 wheel drums, I'd certainly check ANY 66 or prior truck for that rare find of a booster - IF you're going to just retain the stock single reservoir master cylinder. But personally, I'd upgrade to the dual res mc just for the sake of safety).
If planning on front disks/rear drums, I'd grab a master/booster combo off of a mid-70's impala or something like that.
Regardless, try to get any prop valves, etc and the immdediate mc area brakes lines also.
and buy Capt Fab's bracket for a few $ and you're set.
Might also help to read this thread, it shows the bracket and it has some other mc/booster combo options: http://67-72chevytrucks.com/vboard/s...d.php?t=347484
Old 08-02-2012, 08:44 AM   #5
McCoyAZ
McCoyAZ's Avatar
Go to Auto Zone and buy new rebuilt that has a lifetime warranty.
I did what you are wanting to do, picked up a booster and master cylinder from the bone yard. It worked a couple of weeks and then failed on me.
Just yesterday bought the Master Cylinder and the booster for $131.00.
Cheap insurance for lifetime warranty if you ask me.
McCoyAZ is offline   Reply With Quote
Old 08-02-2012, 05:43 PM   #6
SRVBLUES64
I have front disc and rear drums port valve and dual master Im looking to add a booster to be safe any thoughts
Old 08-02-2012, 06:29 PM   #7
TopFuel1966
TopFuel1966's Avatar
I have a rule of thumb. I never cut corners on steering, suspension, or brakes. If you want a m/c with a long service life go to a good parts house and get a new name brand unit. If you want to be returning it on warranty every couple or three months get rebuilt junk from O'Reilly's, Autozone, etc. Costs a little more but well worth it for the peace of mind.
TopFuel1966 is offline   Reply With Quote
