Old 08-01-2012, 09:04 PM   #1
Mb72build
72 C10 wheel help
hey guys, new to the site and building a 72 C10 LWB highlander. it has good BFG tires but want to put some American Racing or Cragar 5 spoke wheels on when its done. I got the 15" 5x5 but not sure about the offset and backspace stuff. What offset do you think is best on my rig? Its disc front/drum rear. Also where is best to buy wheels? Thanks
Mb72build is offline   Reply With Quote
Old 08-06-2012, 11:55 PM   #2
heathbirkendahl
Re: 72 C10 wheel help
I could use some help here as well. Any rim ideas pointers would be awesome. I'm hearing of a few nightmares of getting wheels to fit.
1971 C/10 - Orange & White
2009 GMC 1500 - Lowered 3/4 22' KMC Slides
heathbirkendahl is offline   Reply With Quote
Old 08-08-2012, 05:52 PM   #3
Mb72build
With no response I've scoured the web and believe my truck came with 15x8, 5x5 pattern, and 4" backspace. Anybody ?
Old 08-08-2012, 09:55 PM   #4
Pro Performance
Pro Performance's Avatar
I am not sure what came factory on your truck, but I think it is safe to say it was close to what you mentioned. You can measure the backspace, by measuring from the mounting surface of the wheel, to the very back edge of the wheel. Not the little step, but the very edge of the wheel. In other words, if there was no tire on the rim, you could lay it face up on the ground and measure from the ground to the wheel mounting surface of where it bolts to the truck.
The width of the wheel can sometimes be difficult to measure with a tire on the rim, but you measure from very outside edge, to very outside edge. Then take that measurement and minus 1". That will be the width of the wheel as advertised. Meaning, every wheel approx. measures 1" wider than stated. This is because they call a 8", the width from just inside the bead. With the bead, it actually measure apps. 1" wider.
Hope this was helpful.
Travis
Pro Performance is offline   Reply With Quote
Old 08-08-2012, 10:00 PM   #5
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I just bought these and they are nearly identical to the back spacing of the 15x8 rallys from the 73-up version.
http://www.amazon.com part number VN5155873
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 08-10-2012, 02:52 PM   #6
Mb72build
Thanks guys. I think Im on the right track now. I really like the AR 61ss wheels..
