AC drier direction?
I just bought a new drier for my factory AC Cheyenne in preparation of installing a new condenser and then charging the system.
The drier is marked on one side of the connections with the word "in". Can someone help me understand which hose goes into the "in" side? thanks Posted via Mobile Device |
Old member
Typical system.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: AC drier direction?
In goes to the condenser, out goes to the expansion valve.
That Sir, is a GREAT diagram.
That helps quite a bit. thanks Posted via Mobile Device |
Old member
Your welcome.
That diagram shows a "h-block" style expansion valve and not what GM used back in the day. Only differences are that the low side will not pass through the expansion valve and yours should have a POA valve at the evaporator outlet.
