Old 08-01-2012, 10:10 PM   #1
Touchdown67
Touchdown67's Avatar
Cab mount bushings
I just put a new set of rubber cab mount bushings on my 65 C10 and the cab sits lower than the bed. I tried stacking the bushings backwards so the top bushing was on the bottom and it lined up better but the bushings split after 4 months. I was wondering if anyone else has had the same alignment issues or is there a different brand of bushings that fit better? Also the squeaking of the bushings is louder then before.
Touchdown67 is offline   Reply With Quote
Old 08-02-2012, 08:47 AM   #2
64fleetside
Re: Cab mount bushings
I have the urethane ones. They seemed to fit fine. Washers can be added to raise the cab small amounts.
64fleetside is offline   Reply With Quote
Old 08-02-2012, 09:30 AM   #3
padresag
what is under the bed for insulators. perhaps it has been replaced and is to thick
what shape are your cab supports and floors. the frame brackets also rust out around the holes and have to be rebuilt sometimes
ron
padresag is offline   Reply With Quote
Old 08-02-2012, 10:00 AM   #4
DURG
DURG's Avatar
My cab had square shims from the factory under the cab on top of the bushing stackup, in addition to the large washers. These were slightly less than 1/8" thick. Also how much lower is the cab sitting? Lastly, can you tell me what thread size your rear bushing bolts were (7/16" or 1/2") ?
DURG is offline   Reply With Quote
Old 09-01-2018, 02:07 PM   #5
nibulus
nibulus's Avatar
Where do you guys buy your (rubber) bushings?
I‘m not sure if LMCs kits are rubber or polyurethane...
Part # 30-0082 FRAME MOUNT KIT-28PC
Any other good providers than LMC?
nibulus is offline   Reply With Quote
Old 09-02-2018, 12:50 AM   #6
Captainfab
60-66 Nut
I prefer to buy from these guys.
https://www.classicparts.com/1963-66...info/35%2D141/
Old 09-02-2018, 01:05 AM   #7
nibulus
nibulus's Avatar
Thanks!
They also seem to provide a radiator support mounting kit.
