Old 08-02-2012, 12:18 AM   #1
70K10Hunter
70K10Hunter's Avatar
Burb tank for a 70K10
I am gathering parts for my K10 build, and just like most I will relocate the fuel tank between the frame rails where the original spare tire went. I have heard most use the Blazer tank couldn't find one so I scored a burb fuel tank out of a 89. Called the Chevy dealer and found out it is a whopping 40gal Yehhh Buddy!! got some capacity now. Measured to the top of the filler tube it is approx. 15" high. I guess it will stick down a little further than maybe anticipated but no worries the truck will get lifted and I will build a bullet proof skid plate for it. The truck I'm building had the aftermarket saddle tanks on it with the tank selector valve on the driverside floor, not gonna need those anymore! the tank I am using is from I believe a fuel injected TBI engine(not sure) any way got the filler tube the tank and the pump for 60 bones. Does any body know what fuel pressure those pumps run at? I haven't decided what engine I will use yet. Could I use this pump setup with a carb, and fuel pressure regulator?
70K10Hunter is offline   Reply With Quote
Old 08-02-2012, 12:27 AM   #2
BlackhillsHD
BlackhillsHD's Avatar
Re: Burb tank for a 70K10
Yes you could run that pump but you are still going to need to run a regulator as they run too high of pressure for your carb.
1970 : Chevy: K20 "Frank the Tank" 6.0 LS, 4L80E, 14 bolt, and Dana 44
1970 K5 Blazer CST 350, TH350, Np205, Dana 60 and 14 bolt
General Motors Master Certified wrench swinger
ASE certified Master auto tech
Instructor of Automotive Technology
BlackhillsHD is offline   Reply With Quote
Old 08-02-2012, 12:38 AM   #3
70K10Hunter
If I run a regulator will it make the pump run too hot and shorten its life? I know the fuel cools these pumps but just saying?
Old 08-02-2012, 10:20 AM   #4
SunSoaked
SunSoaked's Avatar
I am doing this exact swap. Theres more photos in my build thread. It actually bolted in very easy. I havent got the fuel filler/door worked out yet until i get the bed back on. I'm going to fab in a fuel filler door behind the wheelwell ( got the door and hinge assembly off a 86 blazer). But anyway, I would not use that pump with a carb. It's almost 35 psi vs 5-6 for a carb. I'm running pro-flo (EFI) and I need to contact edelbrock and see if the stock pump (454 TBI) pump will work. If not, I'll stick with the external pump and mount it on the frame.
SunSoaked is offline   Reply With Quote
Old 08-02-2012, 11:06 AM   #5
70K10Hunter
yeh wow thats too much pressure, if I stay with the carbed engine I will probably gut the pump/pickup assembly to maintain my fuel draw and guage.
Old 08-02-2012, 01:15 PM   #6
61K10
61K10's Avatar
can you post the dimensions of the burb tank--thanks
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 08-02-2012, 02:06 PM   #7
SunSoaked
SunSoaked's Avatar
40 Gallon; 35" x 28-3/4" x 13-1/8"
Old 08-05-2012, 12:35 PM   #8
'63GENIII
'63GENIII's Avatar
I'm gathering parts for almost the same swap. I needed a pump to put out @50 psi for the '97 454 that I'm swapping in. I went to Napa and got stock '97pump for a 454 and replaced the one from the '89 Blazer tank which put out@ 35 like you said. They looked and fit identical. K10Hunter- you could probably just remove the pump from the '89 tank, extend the pickup to where the bottom of the pump was and just use the stock mechanical pump on your engine. I'm not sure about the gauge compatibility though. The new sending unit is something like a 90 ohm and the gauge in my '63 is a 30 ohm, so I had to re-wind the sending unit to work with the original gauge. Not sure when they went to the higher ohm gauges.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 08-05-2012, 02:25 PM   #9
70K10Hunter
Yeh on the later models they bumped the ohm rating to 90, I believe that is what is standard nowadays. I think it was 66 or 67 they made the change.
Old 08-05-2012, 02:33 PM   #10
70K10Hunter
Sunsoaked: I remember reading your thread when I first found this site so I checked it out again, you are farther along than me. Yesterday I picked up a bed floor and did the needed few minor repairs (welded up some holes)I am not looking to build a one off truck just a quality all around/hunting rig, so now that you mention it I will have to go get a fuel door assy and do the same as you and fab it in.
