Old 08-02-2012, 12:39 PM   #1
Geos 72
Geos 72's Avatar
Rubber mat for high or low hump
Hello to everyone out there, ok, I got a good question this time. I'm thinking of putting in a new full rubber mat in my 72 Chevy Cheyenne C10. It is a 2 wheel drive and was a column shift until someone put the shift on the floor before I bought it. Do I get a mat for a high hump or low hump. I'm thinking low hump but I'm not sure. George
Geos 72 is offline   Reply With Quote
Old 08-02-2012, 12:40 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Rubber mat for high or low hump
If the hump bolts in, it is a high hump. If it is welded in, it is a low hump.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 08-02-2012, 01:13 PM   #3
Geos 72
Geos 72's Avatar
Thank you for that info. So if the hump is a low hump I should get a mat for a low hump regardless of where the shifter is?
Old 08-02-2012, 03:04 PM   #4
Tim Christian
Tim Christian's Avatar
Correct
Tim Christian is offline   Reply With Quote
Old 08-02-2012, 03:12 PM   #5
Geos 72
Geos 72's Avatar
Tim, I thank you very much sir.
Old 08-02-2012, 03:14 PM   #6
Geos 72
Geos 72's Avatar
I would also like to thank leddzepp to.
