63-66 bumper hole spacing
Can anyone tell me the spacing between the holes in a front bumper? The 60-62 has a 26 1/4" spacing. I'm hoping the 63-66 is wider and will fit my non factory frame better.
Posted via Mobile Device |
Re: 63-66 bumper hole spacing
Bump, any help with the spacing of the 63-66 front bumper frame bolts?
![]() ![]() Join Date: Jul 2002
I remember hearing folks at a cruise last year talking about the difference in the rear bumpers because of the frame width difference. I know that the 60-62 are narrower in the rear. so I am thinking it is probably the same up front. Unfortunately I do not know the dimensions to help.
The top holes measure 27" edge to edge of hole
The bottom holes measure 26 3/4 edge to edge Hope this helps
'66 chevy lwb c10 '65 chevy lwb c20 |
![]() Join Date: Aug 2010
I apologize for such a slow response to your simple request. I have measured both my '62 and my '66 and they are exactly the same at 26 3/16". Good luck.
Thanks for checking.
If the spacing is the same, why do they sell two different bumpers? Is it the side support hole? Posted via Mobile Device |
#7 | |
ron |
It's the front bumper I'm interested in. At Classic Chevy Parts they sell a front bumper for 60-62 and one for 63-66. http://www.classicparts.com/Bumpers/products/242/
What's the difference? |
#9 | |
I do have a 62 frt bumper for my 64 my reference to the rear was a quote to someone else who stated that the rear was narrower on the 60-62 ron |
#10 | |
ron |
how can you tell what year of bumper you have. My registration says it is a 63 but it has a 62 grill and torsion bars.
#12 | |
some places didn't register the year until it was sold. if your truck was sold in oct. 62 say when the 63 production was out, it got registered as a 63 ron |
#13 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
I don't have the dimensions for the different front bumpers handy, but I can get that info tomorrow if someone else doesn't beat me to it. The rear frame on the '60-'62's is wider than the '63 and up trucks. The side to side hole spacing on the '63-'66 frame horns is close if not the same as '67-'87 trucks.
#14 | |
ron |
#15 | |
on the 84 4 x 4 frame that I have here the outside top of the frame is 28" and then tapers in to the bottom(same place where yours is cut off). my 64 frame horn measures 28 3/4" and is straight down. a 62 bumper fits om mine ron |
#16 |
Ok, I have an answer. The holes are the same spread width-wise on early and late front bumpers. What differs is the spread between holes vertically. early bumpers ('62) have a spread of about 3 3/8" center to center, with the upper hole center down about 3 7/16" from the top edge of the bumper. On later bumpers ('65) the vertical spread is 4 7/8" c to c with the upper hole center at 2 3/4 down from the top edge. If there is a difference in profile, it's not easy to see without a cross section comparison, but the difference in hole spacing is plain as day if you look for it. Funny how you don't notice some things until someone suggests you open your eyes. So lame it took this long to get you that info. Hope this helps
#17 |
here's a '62 and a '63 for side by side comparison. not very good pics, but you can easily see the difference in spacing.
#18 | |
the vertical distance does make sense as the earlier frames are not as high as the later frames ron |
#19 |
I have the same problem. must be a different bumper year.
#20 |
After learning the information from above, mine must be a 63-66 bumper on a 60. My frame is not original. Thus it could have came from any year. It's good to ID the bumper since I want to put the matching one on the rear.
#21 | |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#22 |
This old thread just saved me an afternoon of scratching my head asking wtf? Thank You!
66 GMC brought back from the dead. Project Truck 5 lug power conversion 350 tbi 700r4 |
#23 |
Fantastic work here guys. I know it's an old thread, but a great nugget of 60-66 information
#24 | |
Just wanted to verify that Ron (padresaq) is correct regarding the different shape of the 60-62 to the 63-66. Although width wise the front of the 60-66 frames are the same distance apart laterally, the space of the bolts vertically are different. Also as Ron mentioned; the shape/contour of the 60-62 bumpers are different than the 63-66. I was hoping to use a 65 cut off section of the frame horns on my 62 frame to repair my cracked 62 frame horns, but the cross section contours are different. Also, you can see this shape difference if you look at the side by side comparison pics that oem4me posted,
#25 | |
