Old 08-03-2012, 06:39 AM   #1
Mstl67custom
73-87 front crossmember on a 67 c20 bolt on?
Mstl67custom is offline   Reply With Quote
Old 08-03-2012, 06:41 AM   #2
Mstl67custom
Re: 73-87 front crossmember on a 67 c20 bolt on?
I have a 67 3/4 with front drum brake, does a 73-87 front crossmember with all the steering linkage is a direct fit? And can i use a 88 and up crossmember?
Old 08-03-2012, 07:00 AM   #3
hugger6933
The frame changed in 1988 when the General did a revamp on the truck for the model year 1988. The 1988 frames were boxedall the way past the gas tank and the front crossmembers were welded into the frame, so no they will not work the same as the 87 and back lower "boltin" crossmembers. Jim
hugger6933 is offline   Reply With Quote
Old 08-03-2012, 07:42 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
73-87 is a bolt in swap.
You might have to drill a couple holes.
People have been doing this swap for many years.
Keith
Convert to disc brakes.
Old 08-03-2012, 07:43 AM   #5
lolife99
lolife99's Avatar
The 73-87 steering box might need some adapter brackets because your 67 frame doesn't have a dimple in it to clear the later model steering box.
Member CaptainFab sells those adapters.
Keith
Old 08-03-2012, 03:34 PM   #6
RocketKing
RocketKing's Avatar
I used an 85 front suspension on my 67 frame. I had to widen two holes and drill two and everything else bolted in. As Mr lolife said you will have to consider the non dimpled 67 frame.
The Captain Fab bracket is a great product but I cut a small incision on the top and bottom of my frame, laid a piece of pipe on the location and whacked the pipe with a rather large hammer.
Then I welded the now closed gap back up, some grinding and paint. I don't think anyone could tell it from factory now. I also had to grind a little on the bracket where the core support mounts to the frame. It really was not that hard of a job. I am sure you could do it.
Rex
RocketKing is offline   Reply With Quote
Old 08-03-2012, 03:54 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
Here is a thread where I posted some pictures...
http://67-72chevytrucks.com/vboard/s...d.php?t=272538
LockDoc
Leon
Old 08-03-2012, 04:00 PM   #8
John Fabris
TOTY 2006
John Fabris's Avatar
the disc brakes on 88 and newer are smaller (thinner), so stick with 71-87 for upgrading from front drum to front disc.
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 08-03-2012, 07:20 PM   #9
Mstl67custom
Ok thank, so i'm gonna look for a cheap 73-87 truck in my area
