Under Construction
What Do You Guys Do For Washer Nozzeles?
One of my nozzeles is plugged and they are not that great anyway, so I was wondering if anyone has done some kind of upgrade. Was thinking about hood mounted ones but not sure I wanna drill holes without seeing what it would look like. Surely someone has had issues with theirs. Lets see some pix please.
72 chevy 4x4-my project 67-72chevytrucks.com/vboard/showthread.php?t=368210 94 Nissan 4x4-Daily Driver and off road beater 03 Saab 9-3 -tripper 90 Polaris Trail Boss- 2 Stroker |
Re: What Do You Guys Do For Washer Nozzeles?
You can usually clear them out with a fine drill bit.
I bought some from LMC that I was going to mount on the cowl, but I'm also looking into adapting the wiper arms (instead) to use the squirters that mount onto the arms that the newer models use.
......its not what your askin', its what your gettin'.... .......every time I screw up, I learn something. Needless to say, I'm learning all the time............ |
#3 | |
The Older Generation
LockDoc
Old member
I did this mod 10-12 years ago. this way you get full windsheild coverage also. I love them.
Got everything out of a small GM car, tank with electric pump and nozzles. Wired it to the factory switch. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
i just pull a wire out of a wire brush and use that to ream out the clogged nozzele
been doin that way since the 60's
Under Construction
I tried the drill bit idea, but I don't have one long enough.I'll have to try and find a longer one.
Leon, thanks for the offer. I might take you up on it if I can't clear mine. Thanks for the pix Andy. I'm looking for ideas like that, but if it's been so dry here that wipers may become an accessory!
