Old 08-03-2012, 01:18 PM   #1
mtruckr
mtruckr's Avatar
Question radiator question
I was in a hurry when replacing my '66 Suburban radiator... did not look carefully. Wonder if the u-shaped holding brackets underneath the radiator have bolt attachments to the rail that supports them ??
I used a full-size Pontiac radiator in place of the original radiator for a 305V6. It's a fine fit... almost !
The driver's side u-bracket is soooooo close to the new lower water outlet that the hose clamp has trouble sliding over the hose.
If I could move that bracket juuusssst a bit closer towards the middle... it would be beautiful.
Opinions and input, please.
Thanks-
mtruckr is offline   Reply With Quote
Old 08-03-2012, 01:25 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: radiator question
Yes, I have moved the lower radiator saddles depending on the radiator application (e.g., to clear transmission cooler ports, etc.). I've drilled the new location on the lower mount and used a regular nut a bolt under the rubber bushing in the past to reposition the saddle(s).
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-03-2012, 01:31 PM   #3
mtruckr
mtruckr's Avatar
Sounds easy enough... (famous last words).
Thanks, vin
