08-03-2012, 04:43 PM | #1 |
msd distributor trouble
i have a magnetic pickup ditributor and my ignition box doesnt work ... i am wandering if i can wire my distributor and blaster 2 coil up to run without using the ignition box.... i have a extra coil from a vortec motor can i use it... i am just wanting to run the motor enough to keep the motor lubed up (not trying to drive it this way) or any ideas??
08-03-2012, 11:04 PM | #2 |
60-66 Nut
Re: msd distributor trouble
Maybe, maybe not. Some MSD distributors will not run without a box, others will. You need the part number of your distributor, and then look on MSD's website and see what it says about that model of distributor. I don't know about the Vortec coil, but I doubt it would work as those are designed to work in conjunction with a PCM.
