It'll Buff Out!
![]() Join Date: Apr 2007
best order for installing new wiring and A/C inside cab
Just wonder if anyone had tips on which was is easier.
Should I install all the A/C duct work then the electrical? Electrical first, just don't secure it until duct is in? Any tips would be great I'm installing New truck wiring harness Column A/C ducting Thanks
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB |
Hand Crafted C-10
![]() Join Date: Aug 2006
Re: best order for installing new wiring and A/C inside cab
Route & secure electrical completely, install column, then ducting...
opposite of normal removal I would think. Last edited by ETsC10; 08-04-2012 at 11:30 AM. |
Mine is torn apart to repaint, so I removed a/c duct and will be replacing glove box. Also I made a clamp to keep some of the wire bundle out of the way. Also found some polyester sleeve to run wires in... Wiring comes with minimal instructions on routing wires. Good Luck
