Old 08-04-2012, 08:27 AM   #1
66clow
66clow's Avatar
Diy roof rack 2 fleetside?????
With the success of DWC'S sweet roof rack on his burb it got my wheels turning. Roof rack on a fleetside???? I was familiar with i.o.racks on VW singlecabs so why not a fleetside??? I quickly found a sweet deal on Craigslist for the same brackets as DWC'S for 25 bucks. Here is the mock up stay tuned off to Lowe's to pick up some wood. Open to ideas before it is too late.
66clow is offline   Reply With Quote
Old 08-04-2012, 11:26 AM   #2
oem4me
Re: Diy roof rack 2 fleetside?????
Cool. Since the truck rack is going to be much shorter than the burb rack, the same length load would have less support and create greater stress on the cross rails (in my mind, I picture a surfboard). I would beef up those rails a bit to be safe, and use some good strong wood like oak or ash. Have fun.
Old 08-04-2012, 11:59 AM   #3
DoubleL
DoubleL's Avatar
Can't wait to see the finished project.
DoubleL is offline   Reply With Quote
Old 08-04-2012, 12:23 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
cool idea. My 66 step had a roof/ladder rack on it at some point. I never saw it, but the holes in the bedside and dimples on the roof tell the story lol.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-04-2012, 01:49 PM   #5
MusicMan70
MusicMan70's Avatar
Nice and Good score on the brackets too!
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 08-04-2012, 03:49 PM   #6
66clow
66clow's Avatar
OK I'm stuck and not sure where to go. I have 1x3's going across which seems OK. Not sure for the top. The 1x 2's seem kinda wimpy showing on the Dr's side not sure if I should do the 1 x 3's showing on the passenger side. Thinking possibly 2 x 2's to give it some meat see picture of 2 1 x 's together. What you think?
/IMG]
Old 08-04-2012, 04:22 PM   #7
66clow
66clow's Avatar
Old 08-04-2012, 05:55 PM   #8
oem4me
The 1x's front to back are fine. where you need girth is in the two cross rails that have the brackets attached. Those two pieces hold the whole load.
Old 08-04-2012, 06:11 PM   #9
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
It might make noise as the wind goes through and across the wood. Try to radius the face of the boards to break the wind noise. I like the way it looks. If you use hardwood you might be able to have a xylophone up there. Looks great.
Old 08-04-2012, 06:30 PM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I like the combo of wood and tube like on the old Westy' roof racks.
Old 08-04-2012, 06:43 PM   #11
66clow
66clow's Avatar
That definitely be my choice if I could bend and weld tubing. I will incorporate some type of metal railing. Thanks
Old 08-04-2012, 07:48 PM   #12
66clow
66clow's Avatar
I think what I will try is to put rails along the sides of the cross rails. Do you prefer the wider 1 x 3's or the skinner 1 x 2's? I don't plan to put much weight up there but I do see what you are talking about supporting anything.
Old 08-05-2012, 02:12 AM   #13
oem4me
1x2 rails alongside the 1x3 would really help the strength, hopefully without making it look too bulky. Perhaps even a single 1x2 glued and screwed underneath making a "T" in between brackets would do?
Play around a little to see what looks right.
BTW I really like your truck. The color, wheel and cap choice, stance, everything. Have fun.
Old 08-05-2012, 12:22 PM   #14
66clow
66clow's Avatar
Thanks for the compliment, I appreciate the feed back. I really like the metal tubing with the wood and may check to with some of my body shop connections to see about welding in some tubing. I like the T idea and will probably incorporate that and use oak wood in the end after the mock up. I will post an update as I go along. I also found this rack which is pretty sweet below.
I'll figure something out.
http://classicracks.com/racks.htm[IMG]
http://classicracks.com/racks.htm[/IMG]
Old 08-05-2012, 07:12 PM   #15
purzell
purzell's Avatar
Hey there...what is the brand of those rack towers? Thank you.
purzell is offline   Reply With Quote
Old 08-05-2012, 08:45 PM   #16
DWC
DWC's Avatar
Awesome, looks like its coming along nicely. I think OEM's idea of making the cross beam a "T" section is a good one. That's the same issue I had with the cross car beam flexing and why I ended up with a U shaped support. Your slats will be shorter in length and will weigh less than mine did so a T should work fine. IMO.
I wanted one of those classic racks from your link but couldn't afford it, that's why I made my own. Can't wait to see it finished, Dave
DWC is offline   Reply With Quote
Old 08-05-2012, 10:23 PM   #17
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
T is a great idea. Even a 1/2 or 3/4 stock under would be fine.
The trick is to glue/clamp/screw with a slight bow. Even like a 1/2" deflection.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 08-06-2012, 09:06 PM   #18
66clow
66clow's Avatar
I've been waiting on your expertise to thime in. Do you think I should use the 1 x 2's or 1 x3 's for the slats? I thought you had 1 x 2 's but once I bought them and I saw how many I used and realized you had the 1 x 3's. I thought this was easier than it looks. Still gotta figure out a spot for some type of railing to finish it off.
Old 08-06-2012, 09:25 PM   #19
DWC
DWC's Avatar
Yep, I used 1x3's for just that reason. I could use fewer of them and space them out a bit. You should have seen the looks as I laid it out on the Home Depot floor. If you run the slats out closer to the edge of the cross car beam you could attach the rail to the outermost slat. I had already notched my beam and assembled the slats or I might have added another slat and done this.
It's not easy but not so hard either, just take your time and mock up your idea you'll find something you like. In the end it is just wood, you can always change it. -Dave
Old 08-06-2012, 09:42 PM   #20
DWC
DWC's Avatar
Sorry, I had total brainfart, I used 1x4's for my slats. Went out to the garage just to be sure.
Old 08-11-2012, 08:58 PM   #21
66clow
66clow's Avatar
Update on DIY roof RACK. Worked on putting on the T for the cross supports. Much sturdier and looks better. There was too much space between the roof and the bars. Used glue and screws. Thinking of using copper piping for the side rails for something different, what you think? ????
Old 08-12-2012, 12:05 AM   #22
ChevyFreak60
ChevyFreak60's Avatar
The racks looking good bro!! I love the way that truck sits.
1960 Chevy Stepside 2wd
1966 Chevy Fleetside 2wd
1965 Chevy Suburban 2wd
1965 Chevy Fleetside 4X4
1960 Chevy Fleetside BBW 2wd
ChevyFreak60 is offline   Reply With Quote
Old 08-12-2012, 08:33 AM   #23
66clow
66clow's Avatar
Brackets are called quick and easy. The say they are made in Monrovia CA.
Sorry just noticed your?
Old 08-12-2012, 08:46 AM   #24
aerotruk63
aerotruk63's Avatar
These them?
http://www.nrsweb.com/shop/product_list.asp?deptid=1379
Old 08-12-2012, 09:14 AM   #25
66clow
66clow's Avatar
Exactly and it's nice to know replacement parts are still available.
