Clicking noise while rolling?
So I am getting this strange noise like a card in bike spokes. Could it be the U joint needle bearings? Gonna get under there tomorrow but maybe you can help me look in the right spots. Thank you, Timmy
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. " |
The Older Generation
Re: Clicking noise while rolling?
That would be the first thing I would look at. That and the carrier bearing if it has a two piece drive shaft... LockDoc
Sounds like U-joint if it is a long bed check the carrier bearing second and please block the truck up don't trust the jack to hold up the truck while you are under it. Jim
Great minds think alike Jim. I guess I'm just a faster typer... ![]() LockDoc
![]() Join Date: May 2012
do you have spoke wheels....and are you missing a deck of cards....and close pins....ya know how kids are....
I have the same sound coming out of my truck, mine only does it when I back up. I checked my u joints and they're fine. Intrested to see what you find!
http://smg.photobucket.com/albums/v655/aaronhero/ |
Bad needle bearings in a joint normally sound like a rotational squeak or tweet. If its a rotational click or tick you may have a screw or something in a tire. Have a passenger ride with you and stick your heads out the window to verify its coming from the rear and which side.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
#8 | |
They can look and feel fine but if they are dry (no grease) the needle bearings will catch inside the caps and click when it turns. Not saying that's the problem with yours but just something to consider... LockDoc
Funny you say that bmerdoc because last fall when I parked it , it was just a squeak. Then it was gone this spring. Now it's back! But diff noise. I have been hauling dirt, mulch furniture with the truck., so it's gotta be the carrier or the u joints. We will see tomorrow.
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device
If it has gone from a squeak to a click you will probably find that the rear u joint has eaten a couple of the needle bearings and you will find missing bearings in the rear joint cups and a small pile of dust that used to be needle bearings. Pull it and inspect. Good luck and I hope its a cheap and easy fix.
One of the First
![]() Join Date: Jan 2000
Are you running a GM posi/limited slip locker? I just went through this with my Blazer. My rear end sounded fine driving straight foward and reverse. Put it a slow turn in reverse or foward and it made crackling sound and grabbed a bit. Checked everything - ujoints, lug nuts, springs. Turns out I used the cheaper differential fluid for the posi/limited slip. So, I purchased some "GM/AC Delco" posi/limited slip lube and differential fluid. Changed it out and problem solved. Sometimes being cheap dosen't save you any extra cash...
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
lok inside the brake drums for loose hardware
#13 |
Well, found the problem and can't believe I have been driving this thing like this..I will let the pictures tell the story. I helped my father in law the day before taking 4 loads of furniture to his house. Can you believe that i was able to drive it?Much less do 70 down the highway? Gotta love a chevy
#14 |
yep....that will cause some drive shaft flop....
#15 |
didn't read all the posts, but check the torque on your lug nuts.. Happens to me on too many occasions..
Darren
67- 72 Parts collecter |
#16 |
Nice pics. Been there, done that. Good idea to replace the u-joints while you're at it. You'll need to take one apart to replace the bearing assembly anyway.
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() |
