08-04-2012, 10:33 PM | #1 |
Pedal Pad Help Please!
I have a '72 GMC Sierra Grande with an auto trans that I'm swapping to manual and I finally got a clutch/brake pedal assembly thats out of a '69 and I was looking at pedal pads for them but the pedal pads my truck currently has aren't available for the '69 pedals for some reason?!? I was wondering if the '72 pedal pads will work with the '69 pedals or if they're different size's? The reason I want the '72 pads is I think they look cleaner. Any help and info will be really appreciated!
Thanks: Billet man. www.billetworkstactical.com |
08-04-2012, 10:42 PM | #2 |
The Older Generation
Re: Pedal Pad Help Please!
I can't guarantee it but I think they will all interchange. LockDoc
08-05-2012, 07:49 AM | #3 |
There are only 2 types of brake / clutch pads. They are 67-72 standard brake & clutch pad which have a waffle pattern on them and 67-72 deluxe brake & clutch pad which have a ribbed pattern and are supposed to use stainless steel trim pieces. The brake & clutch pads all interchange. The only item that does not interchange is the 67-70 Accelerator pedal will not interchange with a 71-72 accel. pedal, this is because they have completely different mounting methods.
So yes you can use the same style brake pad found on your 72 on the brake & clutch pedals from the 69. You can find ours on the following page of our web site. http://www.gmcpauls.com/pedal_pads_&_misc.htm GMCPaul |
