Old 08-05-2012, 01:37 PM   #1
HTX86chevy
HTX86chevy's Avatar
oil leak
oil leak around oil pan and bell housing. I took a peak inside the bell housing near the flywheel and it all seems dry on the inside. Exterior is wet with oil on both sides of oil pan only near the tranny though. any ideas?
HTX86chevy is offline   Reply With Quote
Old 08-05-2012, 11:48 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: oil leak
Pan gasket.....or look a tad higher, could be the cam position sensor? crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-06-2012, 09:03 AM   #3
HTX86chevy
HTX86chevy's Avatar
Re: oil leak
thanks.
Old 08-06-2012, 11:19 PM   #4
bwood
bwood's Avatar
Re: oil leak
Could it possibly be the oil pressure sensor at the top of the block. I was thinking that the sensor is on the back just like the old small block. I've known a few guys who pulled their hair out looking for similar leaks.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 08-07-2012, 11:49 AM   #5
HTX86chevy
HTX86chevy's Avatar
Re: oil leak
Well, I replaced the Oil pan gasket and it didn't fix it. It is leaking a lot and since this is my work vehicle (construction) I can't afford to have it sit any longer. I took it to my mechanic and they said it is definitely the rear main seal @ $435.00 Ouch! I can't cry about it. I spent the whole day yesterday and spent almost $100.00 and still didn't fix it. That is what separates the novice mechanic from the experts lol!
