08-05-2012, 07:59 PM | #1 |
Off-Road Brake Discussion
Okay, so a few months ago I redid all the brakes on my K10, and had great brakes. Now the rear drums are completely shot and front discs squeaking like crazy. I have only driven the truck a few hundred miles, but it has gone through alot of mud.
I swapped in ceramic pads in the front and cut drain holes in the bottom of the rear drum backing plates. What are you guys doing to make your brakes last? |
08-05-2012, 09:01 PM | #2 |
Re: Off-Road Brake Discussion
If you drive in a lot of mud and water not to much you can do, mud is liquid sand paper to brake pads.
I have a atv that all it does is go through mud and water and it eats brake pads about every 100 miles or so. Posted via Mobile Device |
08-05-2012, 10:14 PM | #3 |
Wash it.
08-05-2012, 11:50 PM | #4 |
^ x2
1986 GMC K15 4.3V6/SM465/NP205 will be converting to 5.3LS E-ROD/AA adapter/SM465/NP205 10 Bolt Axle Rebuild Tutorial: http://67-72chevytrucks.com/vboard/s...d.php?t=536415 |
08-06-2012, 07:50 AM | #5 |
Convert to disc's on the back.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
08-07-2012, 11:47 PM | #6 |
I never had any problems with drums and mudding through a whole lot of water my brakes were always good but i also took the hose thoroughly to the brakes after i was done but i absolutely hated after it rained my rear drums would be so touchy it would put me against the windshield, converted to rear newer FF with drums now
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
