08-05-2012, 09:02 PM | #1 |
removing crossmember
I have decided to use a 700r4 in my 4 wheel drive 63 suburban, with a 350 motor. I'm going to get a trans crossmember from Bowtie Overdrives. I have searched and couldn't find the thread, but I think I read on here that removing the existing bell housing mount crossmember could allow the frame to flex. That, coupled with the difficulty involved in removing the rivets holding the crossmember in (I'm not removing the body from the frame) have me wondering if I could just leave that crossmember in the truck. Will that interfere with the 700r4 install? I'm planning to run the exhaust outside the frame, so I don't think that will be a problem either way. Any thoughts on this?
08-05-2012, 09:39 PM | #2 |
Re: removing crossmember
where is your orig thread. it did show how your eng was mounted in there. can't remember. thought that you were with the white one from the west sorry.
you are running stk mounting.so when you remove that b/housing crossmember, you will have no support from your small front rad support back to the rear trans mount c/member that you will put in. that crossmember that you are going to remove supports the frame at the rear of the frt spring ron Last edited by padresag; 08-05-2012 at 09:45 PM. |
08-05-2012, 10:04 PM | #3 |
Hollister, CA.
I would fab up a crossmember under the engine, staying clear of the front axle.
Mabey a removable 2" square tube style...bolt in. Wont take much to stiff'n up.... Posted via Mobile Device
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
08-05-2012, 10:47 PM | #4 |
on mine I used an eng crossmember from a 67 or 8 4 x 4 frame. this stiffens up the frame,esp for the steering box.
By rondavid at 2009-03-04 4 x 4 panel and suburban( and other 4 x 4) frames are 2" deeper in the middle section, so don't mount you new rear trans crossmember on the bottom section of the frame as everything will be 2" to low. measure down from the top. I used an orig 2 wheel dr powerglide crossmember in mine an it bolts to the top of the frame and also fab a piece for down below ron |
08-06-2012, 05:58 AM | #5 |
I'm aware that removing that crossmember will leave no support from the radiator back to the new crossmember. That's why I'm asking if I can just leave the bellhousing crossmember in place, and specifically whether it will interfere with the 700r4. I know that the steering box area is especially susceptible to flexing, my son had a 65, and had trouble with the frame after installing PS. My frame has been fishplated in the area behind the steering box (inside of the frame) and has a vertical gusset there as well. My steering box is mounted with cap'n fab's kit. That will probably keep that area from breaking, but I know I need to adress the flex in the rest of the frame.
Bowtie makes a trans crossmember specifically for the 63 4 wheel drive, suburban, which I assume adresses the height issue. Ron, I never started another thread on this issue. Last edited by 63burban4x4; 08-06-2012 at 06:17 AM. |
08-06-2012, 09:42 AM | #6 | |
ron |
08-06-2012, 10:13 AM | #7 |
63, I'm very interested in this thread. I plan on doing the exact same thing to mine next year. Also a 63 4x4 Burb.
What t case are you going to use? Posted via Mobile Device
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
08-06-2012, 01:42 PM | #8 |
Ron, you say that this crossmember issue was addressed the other day.....I'm not seeing that thread, any chance you could link me to it? hey, is that a PTO on the side of your transfer case?
Mike, I'm planning to keep the original divorced transfer case, should just need to probably shorten the jackshaft, according to Bowtie. That way I don't need the 700 with the attached transfer case, it'll be the same trans as the 2WD. |
08-06-2012, 01:55 PM | #9 |
Ron, to be clear, I did see a thread about HOW to remove the crossmember (rivets), what I'm asking is does it NEED to be removed to accomodate the 700r4.
08-06-2012, 02:38 PM | #10 |
08-06-2012, 03:11 PM | #11 |
1961 crewcab
I think it will be in the way, I was going to leave the std shift member in my wifes 63 2wd when I put a v8 auto in it, and there was pretty much no way to work around it, so I ended up cutting it out.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
08-06-2012, 03:32 PM | #12 | |
sorry, to me it wasn't clear at all. What you are, is rude. I've seen you be rude to others here, and I find it totally uneccessary. You may know all there is to know about these trucks, but as far as I'm concerned, you will do me a favor to just ignore my posts and questions here, and I plan to do the same for yours. I'm frankly surprised others have not made the same request. I for one will muddle through somehow. jonz, thanks...that's the info I was asking for. |
08-06-2012, 03:40 PM | #13 | |
Capt fabs kit is a steering box adaptor and will help in preventing cracks at the mounting holes and is good at what it does. even if you box it for a little distance it will more than likely cause cracking where that ends, experience does count at times. put your p/s on there and 33x12.5 tires on there and start turning it parked and see how much that frame moves. just look. it doesn't say that bowties crossmember is for a 4 x4 but ladder back suburban frames from 60-63. should read 60-62 frames from 63-66 are the same. all 4 x 4 frames from 60-62 are the same as are 63-66 except on 63 it allows for the early cab mounting, yet they do not also list a trans crossmember from 63-66 for 4 x 4s. 4 x 4 frames are 2" deeper in the middle area. It does make it easier to install the trans and also to remove it if you ever have to with that crossmember removed from under the bell housing area. you can leave it in there though. you may also have to massage the floor a bit. but for all general purposes and ease of doing things it should be removed and there should be some compensation replaced adjacently ron |
08-06-2012, 03:43 PM | #14 |
A 700R4 won't fit w/o removing the std crossmember.
08-06-2012, 03:48 PM | #15 |
ignore, v. To disregard; to refuse to notice, consider, or recognize.
64fleetside, thanks. Again, that is what I was asking. |
08-06-2012, 04:17 PM | #16 | |
I do have one of those original p/glide crossmembers available. ron |
08-07-2012, 08:37 PM | #17 |
I'm pretty sure you'll have to remove that bellhousing crossmember, as others have said. Some people just cut them out, and leave the riveted sections in the frame rails... I've never been a fan of that. Its not too hard to cut the rivets with an angle grinder and pound them out with a big punch and a 4lb sledge. I took my whole frame apart that way A cutting torch or air chisel would be far fast and less effort. Any muffler shop can probably cut those rivets for you.
You should certainly replace that removed corssmember with another one, under the motor. This is how the 73 and up K-series pickups are built. All the Chevy trucks have at least 5 structural crossmembers. So if you remove the one under old bellhousing you must put another one in under the motor. I would do one of two things: either pull a factory crossmember out of a 73+ K-series pickup, or buy a tubular one from DIY4X.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
08-08-2012, 12:45 AM | #18 |
60-66 Nut
The motor mount crossmember from a '73-'87 Kseries truck will have to be modified to fit an early frame. The '67-'72 K series motor mount crossmember fits with only holes to drill.
Here are pics of installing a '67-'72 motor mount crossmember in my son's '63 K10. Also, in the K series trucks the bellhousing crossmember bolts to brackets on the frame rails.
08-08-2012, 12:50 AM | #19 |
Captain,
Good call. There would have to be some holes drilled to make the 73+ crossmember fit. I was forgetting about the 67-72 as a bolt in. Question for you: I'm looking at the transmission crossmember in that 63 and it looks like it has a center drop-out section. I haven't seen that before...
08-08-2012, 12:58 AM | #20 | |
60-66 Nut
You know, after I typed that, I got to thinking. That drop out bellhousing crossmember may be specific to the '60-'62's. The frame under my son's '63 is a '60-'62.
08-08-2012, 01:02 AM | #21 |
Interesting. It looks pretty slick. Might make it easier to drop the trans down with the bell-housing attached rather than detached through the cab.
08-08-2012, 01:17 AM | #22 | |
ron |
08-08-2012, 05:45 AM | #23 |
Thanks, guys. I knew there were plenty of guys here willing to offer CONSTRUCTIVE advice!
And, thanks for the supportive PM's to all who did so. Most of us know we are here to help each other out! -Ed Capt'n, yeah, I'm pretty sure my BH crossmembe isn't drop down like your son's....my truck is not close to home right now, but I'm going to go by the shop and check....but that seems like a detail I'd remember! I have not taken any of that apart yet, been focused on other things, and just formulated a plan for the trans swap. I was originally just going to leave the 4-speed, I wouldn't mind it so much, but the DW said she'll never drive it without an automatic.....and you never know when you'll need a reliever! Last edited by 63burban4x4; 08-08-2012 at 05:59 AM. |
08-08-2012, 05:20 PM | #24 |
Had a chance to go by the shop today, and as I thought, no dropout in my crossmember....but I talked it over with the guy doing my fabricating, and I think we may leave the crossmember in place but cut out the center section just past the gusset that goes to the bottom of the frame, (sorry no pics) and build a drop section we can bolt in place to the original crossmember. . Seems like it would give me the best solution without too much work. Best of all, no rivets to beat out! My original crossmember is bent in the center anyway....somebody musta lost some teeth on that hit!
Thanks again for all the advice. When we get to this, I will try to get some pics. -Ed |
