08-06-2012, 12:35 AM | #1 |
Rear Disk Brake Conversion -Dually-
Whos done a disc brake swap on an 87 1 ton dually with a C&C rearend? I am looking for someone that is actually using a conversion to give feedback. I saw one kit that had dual pistions... that would be perfect!
Thanks in advance, Eric Last edited by esbstuff; 08-06-2012 at 01:50 AM. |
08-06-2012, 12:21 PM | #2 |
Re: Rear Disk Brake Conversion -Dually-
Be aware , I looked into doing this conversion, but I think you loose your parking brake. Since my truck has a 4 speed, I didn't like the idea.
Desert |
08-06-2012, 12:45 PM | #3 |
I guess I should have said that I need to keep the e-brake. I don't want to be winching on the parkpaw alone...
08-06-2012, 01:46 PM | #4 |
Not sure about a c&c rear-end, but when I did my Dana 70 dually disc conversion, I had the option of putting 1978 Cadillac calipers on my brakes and keep the e-brake. As far as brackets, can't say I have seen those for a cab and chassis.
08-06-2012, 01:51 PM | #5 |
http://diy4x.com/cart/index.php?rout...product_id=150
http://www.ruffstuffspecialties.com/catalog/14BCNC.html Looked around real quick and these are what I found. I have dealt with Kert at www.DIY4x.com and cant say enough about his level of quality and customer service. Check into it a little more, but I am pretty sure the Caddy calipers will work and allow you to maintain an e-brake. |
