![]() Join Date: Jun 2006
Help needed with parking brake problem on my 72
The pedal will not set on my 72 when I push it down. If I push in on the
release handle while I push the peddle down the teeth will catch and hold. Is there a spring or something that is broke or missing? Thanks! Bob |
Re: Help needed with parking brake problem on my 72
There is a spring on the back side of course. Can't find it in the parts manual right now, but then I'm tired.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
spray the heck out of it with WD40 to clear out the 40years of dust and grime then work it to free up those moving parts after that spray it with some white lubriplate to keep it lubricated redo every 10years or so
SS tim thanks for the pic I have the same problem but I don't have a spring, look like I need to get a spring now.
just like that old Johnny Cash song. "One piece at a time and I am go na make an old C10 mine a look at all your faces when I drive through your town" |
The spring was missing. Put in a replacement, lubed the moving
parts and all is good! Thanks for the help fellas! Bob |
I see you found your fix, that's great!
I had this problem as well, and for what it's worth, I had an old throttle return spring that worked perfectly. |
