08-06-2012, 01:07 PM | #1 |
Quick 5 lug conversion question...
Wondering if anyone can help with a control arm question...
What is the difference in the upper control arms from 67-70 and 71-72.. would it just be the size of the ball joints? I am wanting to use both upper and lowers from a 72 on my 69 cross member during the disc brake conversion. Thanks in advance. jimmy Last edited by ~Whitey~; 08-06-2012 at 01:24 PM. |
08-06-2012, 01:49 PM | #2 |
Msgt USAF Ret
Re: Quick 5 lug conversion question...
Read this thread carefully. I think it will help.
....http://67-72chevytrucks.com/vboard/s...d.php?t=456889
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
08-06-2012, 02:23 PM | #3 |
Thank you very much. That helps a lot and what I take away from it is:
You match ball joints to the year of the spindles and it doesn't matter what year of 67-72 control arms you use. |
08-06-2012, 08:01 PM | #4 |
Msgt USAF Ret
Here is another thread on the disc brake swap that you might be interested in.
............http://67-72chevytrucks.com/vboard/s...ad.php?t=35042
08-06-2012, 08:09 PM | #5 |
67-72 parts collector,…
Balljoint is the only difference in the 67-72 arms.
C20/C30 lower arms however are different. Larger balljoint hole. Posted via Mobile Device
