Old 05-22-2003, 04:02 PM   #1
Tom
driving is in my blood
Tom's Avatar
Talking I got a front clip finally!!! Few qeustions:
I cant believe I finally found a full complete front end for my truck, about time! Anyways Im going to be removing the entire thing from the donor truck and installing on my 79 within a couple weeks. Where are all the bolts located so I can remove it from the cab as a complete unit? Also, Ill need to remove the radiator and condensor, but is there anything else attached usually?
Old 05-22-2003, 05:12 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: I got a front clip finally!!! Few qeustions:
2 at the cowl, 2 above the top hinge of each door, 2 at the center of the bottom of the fender, 2 at the core support, 4 (2 apiece) on the inner fenders. Unless you yank the wheels off, it is going to be a pain to pull the whole clip off without harming it. In addition, you might want to remove the hood, washer hoses, and unplug the harness from the firewall, and remove the heater hoses.
Other bolts, about 8 (per side) along the inner fender w/3 across the core support. Another 10 (per side) along the core support 2 of which hide under the hood support........ you got the picture right
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
