Old 08-06-2012, 03:24 PM   #1
72hoopti
Carb Problems
I have a zz4 crate motor with a new edelbrock 600 and have had nothing but problems with it. The carb wants to stumble, has problems starting after motor has been run, and has half the guts than the holly that I replaced it with. Anyone else have this problem?
I have replaced the springs in the carb and put a thicker gasket below the carb. I have searched high and low for a vac. leak but to no avail. I have pulled the PCV valve hose off and it still runs. Put two rags over the carb to choke it and it won't die! Any advice is appreciated...
72hoopti is offline   Reply With Quote
Old 08-06-2012, 03:31 PM   #2
cdowns
cdowns's Avatar
Re: Carb Problems
what do the sparkplugs look like?
type of gas pum
ffuel filter?
gas tank and lines clean and freash gas?
Old 08-06-2012, 03:43 PM   #3
72hoopti
Re: Carb Problems
Everything you mentioned is Brand new. Edelbrock suggested the 73x42 metering rods. However, I have tried all of their " kits". Sprayed all over for vac leak and can't find anything....
Old 08-06-2012, 03:47 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Carb Problems
There's your problem! Bolt the Holley back on...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-06-2012, 03:49 PM   #5
72hoopti
Re: Carb Problems
Well Gary, that won't solve my issue with this carb.
Old 08-06-2012, 03:55 PM   #6
GASoline71
GASoline71's Avatar
Re: Carb Problems
Very true... but if you have a known good running carb... why keep messing with this one?
Also... what's the ignition system condition? New as well? What's the timing set at? A lot of "carb" issues can atually turn out to be timing/ignition related.
Gary
Old 08-06-2012, 04:28 PM   #7
Wrenchbender Ret
Re: Carb Problems
Those are good carbs. Check the accel. pump shot. They use a leather cup that can dry out from setting. Is the carb flooding after you shut it off? That carb does not like a lot of fuel pressure. About 4-5 lbs. Have you put heavier springs under the metering rods? You may need to change to a smaller metering rod or a larger jet. That engine probably has quite a bit of cam. It may need a quicker spark advance &/or more timing.
Wrenchbender Ret is offline   Reply With Quote
Old 08-06-2012, 07:47 PM   #8
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Carb Problems
Whats the condition of the carb? What is the fuel pressure it sucks if its not @ 5-6psi.
Are the floats set correctly
5.5 is what eddy recomends i think
John
1999 Toyota Tacoma 4x4
Old 08-07-2012, 11:13 AM   #9
72hoopti
Re: Carb Problems
Well, after a long night turning screws, "starting from scratch", the hoopti is running and running without the stumble and hesitation.
Timing is all up to specs according to GM performance. Put the advanced springs and weights in distributor and made some difference.
My biggest complaint now is there's no guts behind it anymore, with this carb, the truck is a dog!
I am going to put a fuel pressure gauge on it... Will get back shortly
Old 08-07-2012, 01:17 PM   #10
GASoline71
GASoline71's Avatar
Re: Carb Problems
That could be timing as well... what is the "spec" that GM says needs to be used on the ZZ4? Could also be fuel delivery.
Also as stated above... the Edelbrock carbs don't like much pressure above 5.5 PSI. So shoot for that... you might need a pressure regulator.
Gary
Old 08-07-2012, 04:27 PM   #11
Wrenchbender Ret
Re: Carb Problems
Make sure the secondary throttles are opening. If the choke is not opening all the way it can be blocking the sec. from opening. Or your linkage may not be opening the throttle all the way.
Old 08-08-2012, 03:53 AM   #12
oldblue1968chevy
Re: Carb Problems
I have an eddy..it works...(after it was set and regulated).
If I had to do it again Id get a edelbrock fuel pump that puts out the proper psi a fuel regulator is just going to clutter things up.
If/When I start driving my truck again I believe Im going to try to find something other than edelbrock (probably a holley)
John
Old 08-08-2012, 08:46 AM   #13
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
Re: Carb Problems
I was told by my Carb guy that running a regulator will take the pulse out of your fuel system (with mechanical pump) and can increase your mpg by as much as 1
I was not able to prove that, but just thought I would share.
"Instructions are just another mans opinion"
Become a Supporting Member
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
