Old 08-06-2012, 04:36 PM   #1
gringoloco
A guy with a truck
gringoloco's Avatar
Narrowed Control Arms
I have been 'bench exploring' some suspension/braking/wheel options and wondering what, if any, negative effects 1" narrowed control arms would have on the supension geometry. I assume that the camber, and therefore caster gain will be more aggressive, but is this necessarily a bad thing? What other possible side-effects (positive or negative) am I overlooking? Any and all input is appreciated
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-06-2012, 05:10 PM   #2
GEARBOXGARAGE
Re: Narrowed Control Arms
You could check with Heidts, they offer narrowed A-arms for Camaro, Nova and Chevelle. They would probably be able to tell you any pros/cons between stock/narrow set-ups. Just a thought.
GEARBOXGARAGE is offline   Reply With Quote
Old 08-06-2012, 05:33 PM   #3
69gmcc10
69gmcc10's Avatar
what r you doing narrowing conrol arms? Dont you have an LQ4 to install?
69gmcc10 is offline   Reply With Quote
Old 08-06-2012, 05:57 PM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
Good idea! I know PB offers them as well- would like to hear from them or NoLimit as they are intimately familiar with our trucks.
Haha- yes, that is part of what is motivating these ideas. I can already out-drive the truck with its current power plant; that will quickly become an even bigger issue with more HP on tap. The truck needs suspension/brakes so I don't kill myself, or worse, wreck my truck!
-Chris
Old 08-06-2012, 05:59 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Have you discussed this with Nate?
I know he make narrower control arms and the 1" forward version that helps center the wheel in the wheel opening.
(and helps with caster adjustments).
http://67-72chevytrucks.com/vboard/s...d.php?t=537266
Keith
Convert to disc brakes.
Old 08-06-2012, 06:14 PM   #6
67maniac
Was just about to post the same exact thing. Pros-Cons from narrowing .5" compared to 1"?
67maniac is offline   Reply With Quote
Old 08-06-2012, 08:29 PM   #7
gringoloco
A guy with a truck
gringoloco's Avatar
Just spoke with Dave at PB- should be extremely minor effects with coils and only minor camber/caster gains with 'bags due to suspension travel.
-Chris
