drop spindles rubbing 15" rim
I do not know what spindles I have. They came in a package deal. I just mounted my 8" truck rallys and the lower a-arm and the steering arm are extremely close to rubbing. If I turn the wheel to lock in either direction they will lockup on the lower a-arm. They have the casting #'s G M T 130-90 and 218-90 respectively. I'm kinda bummed on this. Any info out there? Thanks a heap and a whole lot in advance.
Herb |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: drop spindles rubbing 15" rim
From what little I know, the edge of the LCA is going to need to be clearanced about 1/2-3/4 inch. you can do this with a grinder.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
The Engine Whisperer
I was thinking the same thing and also adding 1/4" spacers to each side.
67-72 parts collector,…
![]() Join Date: Nov 2002
This is VERY common on any 15" wheel with more than 3.5" backspacing.
Your 8" ralley wheels have a 4" BS. Just trim the lower a-arm with a grinder. Takes about 5 minutes per side.
Junior Member
I also was unaware of this on my build before I bolted up the 8" ralleys and had to clearance the LCA's. There are threads in here with photos so you can see what you're in for. It took me more than 5 minutes.
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
