08-06-2012, 08:29 PM | #1 |
tires
just drop my truck 3-5 and ordered 20 x8.5 and 20x 10 what size tires do I need to order. I was looking at 255/40-20 and 295/40-20. Will this work
08-06-2012, 11:24 PM | #2 |
Re: tires
Yes, but it does depend some on the backspacing of your wheels. What wheels do you have? Do you know the backspacing?
Travis |
08-07-2012, 03:54 PM | #3 |
Re: tires
the rims are raceline burst with 5" b/s
08-07-2012, 04:09 PM | #4 |
Re: tires
thanks for your reply , the rim are raceline burst with 5" B/S
08-07-2012, 05:08 PM | #5 |
Re: tires
They'll work. What are the suspension specifics? 71-72 brakes or?? Pre-70 6-lug 12bolt or post 70 5-lug 12bolt?
08-07-2012, 05:11 PM | #6 |
Re: tires
I apologize, as I should have asked also if you have the narrower rear end. I am assuming you do with the backspace of 5" on the rears. You can clear that tire if you do have the narrower rear end and that backspace.
