Old 08-06-2012, 08:45 PM   #1
Scott26
Scott26's Avatar
can you replace one main bearing cap without line boring
i got a broken main bearing cap, can i put a new one on without having it machined.
1986 GMC Sierra Classic 4X4
Scott26 is offline   Reply With Quote
Old 08-06-2012, 09:04 PM   #2
russgt
russgt's Avatar
Re: can you replace one main bearing cap without line boring
You should have it checked/bored. How did it break?
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 08-06-2012, 09:13 PM   #3
Scott26
Scott26's Avatar
while i was torquing in down it snapped on the side for some reason
Old 08-06-2012, 09:16 PM   #4
Billy81
Billy81's Avatar
I agree with russgt.
Billy81 is offline   Reply With Quote
Old 08-06-2012, 09:54 PM   #5
INSIDIOUS '86
INSIDIOUS '86's Avatar
You sure can. Just replace it with the original otherwise no have it line honed period
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 08-07-2012, 07:45 AM   #6
BigBlocksRule
Take it to your machine shop, most have buckets of caps that have been salvaged off of old blocks. Mine took the time to check several, ended up with one that was a dead-on fit. Saved me some money for sure!
And if you're watching Horsepower TV to learn how to build one, DON'T!!! I cringe every time I see those guys smacking main caps down into the registers with a hammer. You're applying what amounts to reverse direction detonation when you do that. Snug 'em down, then tighten the bolts to get the cap to snap down into the registers.
BigBlocksRule is offline   Reply With Quote
Old 08-07-2012, 07:47 PM   #7
russgt
russgt's Avatar
Lightly taping the cap with a hammer will ensure that the cap has properly seated, preventing what happened here, tightening down a cap and it breaking because it was not sitting flat on the block.
70 stepside
76 blazer
86 Silverado
71 Nova SS
Old 08-07-2012, 08:05 PM   #8
BigBlocksRule
If it broke when he torqued it down into the register, it was cracked. Tapping it on the side where the bolts go, the TV gurus tap 'em directly in the center of the cap.
