Old 08-06-2012, 08:57 PM   #1
62'comingthru089
Where can I get a good rear end for A 62'
I have a 62' with a 350 in it right now i plan on getting a new transmission sometime and want to change the rear gears but I dont know that much about ratios and i dont know if I can just change the gears out or if i will have to get a whole new rear end. I want something that will make my truck badass. I dont care if its out of a car at the junkyard i just would like to know what car or where i could find a decent rear end?
thanks
Jamel
62'comingthru089 is offline   Reply With Quote
Old 08-06-2012, 09:02 PM   #2
pestwagon
Re: Where can I get a good rear end for A 62'
theres a stock 61 shortbed with a stock rearend in it at merced pick n pull. Only a 60-62 will fit right I think...
pestwagon is offline   Reply With Quote
Old 08-06-2012, 11:34 PM   #3
Captainfab
60-66 Nut
Is your truck a Chevy or GMC? A C10 or C20? I assume you are looking for higher gears for lower cruising rpm's?
Old 08-07-2012, 12:32 AM   #4
62'comingthru089
I have a Chevy c10 and I don't know how it works I may need to get a new transmission as well but I'm only pushing 80 miles an hour I mean I want something that I can cruise around in but at the same time if some piece of crap Honda pulls up to me and wants to race I know I'll at least put up a challenge. Does that kind of give u a better idea?
Old 08-07-2012, 12:42 AM   #5
Captainfab
60-66 Nut
A '62 Chevy C10 is most likely going to have a Eaton HO32 differential. The most common gear ratio in those is 3.90. There used to be 3.36 gears available for those differentials, but I don't think they are available any longer. A fairly good all around rear gear is the 3.42 gears. To be able to have those gears you will need to change the entire differential to either a '63-'82 truck 12 bolt, or a '80-'87 truck 8.5" 10 bolt. The late '70 to '87 differentials are going to be 1.5" wider than your current differential. and of course the '71 and up C10's will have the 5x5 wheel bolt pattern. Regardless of which differential you choose, there will be a certain amount of cutting, welding and fabrication involved. You can also go one step further and install an overdrive trans for even more of a decrease in highway rpm's. If you feel the need for increased accelleration, just pull it down a gear or two.
Old 08-07-2012, 09:43 AM   #6
62'comingthru089
So if I went with a later rear end say like 70's to 80's I would have to weld in the. Ew gear box, or if I find a complete rear end from like a late 70's truck I couldn't just swap it out? I mean grated I know it won't line up with the old rear end and I may have to get a new drive shaft but is there no way just to swap it out?
Old 08-07-2012, 10:51 AM   #7
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: Where can I get a good rear end for A 62'
What's your estimated HP/TQ on that 350? What type of trans you are using?
8.8 Rear End that will mount up to a 1962 Chevy Pickup
http://67-72chevytrucks.com/vboard/s...d.php?t=326263
Gear Ratio Calculating - Not bad info:
http://www.chevyhiperformance.com/te...ing/index.html
If you wanna go 9":
Everything you've ever wanted to know about Ford 9 Inch Differentials!
http://67-72chevytrucks.com/vboard/s...d.php?t=454229
For the rice burners....Priceless
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 08-07-2012, 12:43 PM   #8
vin63
It's Better With Nitro
vin63's Avatar
I have an 8.2 rear end out of an S-10 (I think it has 3.08 gear) that you can have for $10 (just diesel money to Oceanside). I'm down your way several times a month since my racing partner and MachineTech Racing Engines are in Oceanside (where I do a lot of my machine work).
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-07-2012, 02:23 PM   #9
62'comingthru089
Do you think that would fit on my c10?
Old 08-07-2012, 02:50 PM   #10
vin63
vin63's Avatar
The housing width is 54.25" with the axle stand out, it is just shy of 60", so it should fit nicely, especially if you want to fit a wider and deeper wheel combo. I acquired it to use on a customer C-10 project, but he sold it before we could use it.
Old 08-07-2012, 02:54 PM   #11
62'comingthru089
Hell yeah man if your selling it for 10$ and it's in good condition I don't think I could pass it up
Old 08-07-2012, 05:24 PM   #12
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
the 8.2 is not a "bolt-in" unless vin63 has already modified it.
Larry
fleetsidelarry is offline   Reply With Quote
Old 01-17-2017, 01:20 AM   #13
62bagger
62bagger's Avatar
Does anyone know the measurement between the trailing arm mounts on a 62 C10?
62bagger is offline   Reply With Quote
Old 01-17-2017, 02:03 PM   #14
61K10
61K10's Avatar
Just for info Yukon gear still make the ho-32 3.38 ring and pinion.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
