Old 05-22-2003, 05:06 PM   #1
GMC70c20
Will it work
I found a cab and doors for 400$ no rust, no dents, the truck that we are going to put it on is a 70 I dont know what year the cab is should I have any major problems. If it has a cables style throttle could I convert it some how to the rod style? and if the e-brake isnt floor opperated could I change to be floor operated(sorry if that coonfused you).
GMC70c20 is offline   Reply With Quote
Old 05-22-2003, 06:06 PM   #2
Class of 69
Class of 69's Avatar
You can interchange almost anything on these cabs, If you have all the parts on one to switch to the other. As far as the throttle set up...I would keep the cable arrangement over the rod. e-brake should swap out..may have to drill a few holes, but it will fit. Nice find on a rust, and dent free cab!!! I'd swap parts too if I found one.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 05-23-2003, 12:13 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If it has a cable throttle, and is original...then it is a 71 or a 72.
No you shouldn't have any real problems.
Old 05-23-2003, 02:33 AM   #4
Phillip Johnson
Phillip Johnson's Avatar
If it has a hand emergency brake, Its a 67 cab..
Phillip Johnson is offline   Reply With Quote
Old 05-23-2003, 11:24 AM   #5
Longhorn Man
phillip, tha hand brake could make it a 68 also.
