08-06-2012, 10:39 PM | #1 |
I need Help guys
I dont like to drive my truck because every time i drive it i cant go pass 45mph because if i do my truck moves to the side and sometimes i hear like a clicking noise in the front left side. Have any of you guys had this problem before?
ps.Do aftermarket lower,upper control arms,etc. makes handling difference? |
08-06-2012, 11:24 PM | #2 | |
Re: I need Help guys
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
08-06-2012, 11:28 PM | #3 |
well the steering wheel starts moving alot
08-07-2012, 11:45 AM | #4 |
78K & 79C Jimmys
4X4 or 4X2
but check rag joint ball joints,if 4X check front drive axels joints,front stabilizer?
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
08-07-2012, 01:05 PM | #5 |
Also check shocks,and idler arm
08-07-2012, 01:30 PM | #6 |
Open the hood and have someone move the steering wheel back and forth. If it's the rag joint or the steering box you will see it.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
08-07-2012, 02:14 PM | #7 |
It sounds to me you have a front tire either out of balance or slipped belt exaderated by bad shocks.
John 82 Chevy Silverado 350ci/TH350 |
08-07-2012, 05:29 PM | #8 |
Truck Nut
Sounds like wheels bearings for sure.
Tony Kee Texas Square Bodies |
08-07-2012, 05:44 PM | #9 |
I agree with jknight on this one sounds like its an unbalanced tire on one side. I have experienced this so bad that I thought that I was going to break my thumbs bc the steering wheel was bouncing so much.
08-07-2012, 05:44 PM | #10 |
Also was really only happening at higher speeds.
08-07-2012, 05:50 PM | #11 |
Jack it up and spin the front tires. Watch the tread of the tire for movement which would indicate seperated belts. Also by hand move the tire in and out at the top and bottom to check for loose wheel bearings.
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
08-07-2012, 06:27 PM | #12 |
I would check the tires first. Long story short if the belts separated and your on the way to the tire shop a tire will blow out, thats my luck anyways. If you went near or over 45 it would jump bad.
1979 Sierra Classic Heavy-half 1996 Silverado x-cab "the daily" |
08-07-2012, 06:38 PM | #13 |
08-07-2012, 06:40 PM | #14 |
one more thing guys it has 20 inch wheels and it has wheel adapeters
08-07-2012, 06:43 PM | #15 |
08-07-2012, 07:08 PM | #16 |
You have a laundry list of things to check already, but add the wheel adapters to that list too.
08-07-2012, 08:53 PM | #17 |
What kind of wheel adapters did you get? I know they make 2 different kinds. The best would be to have the hubcentric wheel adapters because they align themselves right off of your hub, this way it keeps your new lug pattern centered. The other type of wheel adapters dont rest on the hub and are aligned by you when you tighten the bolts down. Ive had the same problem, not on my square but on a car i had at one point. The wheel adapter moved the lug pattern from the wheel a couple millimeters off from the stock position because i didnt have the hub centeric type and at 45mph the car was nearly gunning to the right and hopping like a stagecoach, scared the **** out of me to say the least. Used the hubcentric wheel adapters and fixed everything. Dont know if this helps, just my 2 cents.
1986 GMC K15 4.3V6/SM465/NP205 will be converting to 5.3LS E-ROD/AA adapter/SM465/NP205 10 Bolt Axle Rebuild Tutorial: http://67-72chevytrucks.com/vboard/s...d.php?t=536415 |
08-07-2012, 09:11 PM | #18 | |
78K & 79C Jimmys
i'd go with checkin the adapters
