![]() Join Date: Jun 2012
A/c ?????
Is it easier to install a classic air a/c system on a non a/c cab or just swap cabs that came with factory a/c? I have a 69 without and was thinking about putting a 70 cab with. a/c on.
Posted via Mobile Device |
CAN'T FIX NOTHIN
Re: A/c ?????
I am installing an old air products underdash system on my 67 had asked on here in the last few days for info on ac systems advice or whatever ? They dont seem to be anybody that knows much about them ? I have never had a vehicle with ac before , my system should be here this week when I get it installed I will post how it works
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
Re: A/c ?????
I have a Vintage System and I am using a non ac cab (i have an ac cab also). My kit is not a year specific application, so I wanted a "clean slate" so-to-speak to have the ability to use different (billet aluminim) vents and not be stuck with the stock round balls. Just my .02 cents.
Re: A/c ?????
Ok sounds good.....keep me posted!!!
Re: A/c ?????
The way to go to install air in your truck.Is Vintage Air they have a complete 100% bolt in kits for non factory air trucks or factory air trucks.Once again they are 100% bolt in and they work the best for truck period.If you are looking for great package deal let us know and we will take care of you for sure.You can p/m me or e-mail or call the shop
justin@scottshotrods.com scotts@scottshotrods.com (805)485-0382 |
Re: A/c ?????
If you have a good non-a/c cab and want to install factory a/c it is not that hard to do. Measure twice, cut once.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
#7 | |
Re: A/c ?????
Craigslist: 70 Chevy Classic Truck C-20 Longbed http://lasvegas.craigslist.org/cto/3154096097.html Posted via Mobile Device |
![]() Join Date: Nov 2004
Re: A/c ?????
That's all true, but if the system is apart or has not been charged in a long time you could be replacing the compressor condensor and dryer, which isn't cheap either (ad doesn't say if the air works.)
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Re: A/c ?????
My cab was non a/c and we installed a Classic auto air kit and it has been in my truck for four years and it works flawless in this miami heat..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Moderator
![]() Join Date: May 2007
Re: A/c ?????
The ad does not say if the A/C works or not....which means it doesn't. If it did the guy would be bragging about it in the ad, cause you NEED it in Vegas.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#11 | |
Re: A/c ?????
#12 | |
Re: A/c ?????
#13 | |
Re: A/c ?????
#14 |
Re: A/c ?????
I installed an Old Air kit in my truck. Was simple and blows nice and cold all day long. I would go that route rather then trying to piece together an original simply because as stated previously trying to replace any and all components that are bad would not only be frustrating but will probably cost you more then an aftermarket kit in the long run. Not to mention you either get to stick with R12 and pay a ton for the charge or fork out more money again to update to the R134a. . Just my two cents. hope that helps
#15 |
Re: A/c ?????
Ok cool thanks!
#16 |
Re: A/c ?????
Oh BTW i recommend doing the electronic controls rather then the cable operated unit. reason for this is as follows.
1) check valves tend not to want to shut off completely after time, so your system wont get as cool as it can. 2)the cables tend to tighten up over the years and make it more of a pain "not a big deal just saying" 3) its either hot or cold. There's a bit of adjustment on the heat but on the AC the micro switch is either on or its off. So cold or not. reason i like electronic controls is as follows: Valve is electric and works every time from my experience with it. and you have a full range of adjustment of temp. much better options for keeping the cab comfy. |
#17 |
Re: A/c ?????
I did an install thread on the Vintage Air set up. It's awesome.
http://www.67-72chevytrucks.com/vboa...d.php?t=249479
#18 | |
Re: A/c ?????
Nice write up man! |
#19 |
Re: A/c ?????
Ok awesome thanks!
#20 |
![]() Join Date: Apr 2012
Re: A/c ?????
I'm also looking at the vintage air and classic auto kits. Have heard nothing but great reviews from both.
#21 |
Re: A/c ?????
No problem.
Mine's been blowing ice cold since '07.
#22 |
Re: A/c ?????
Awesome great!!!
