Old 08-07-2012, 02:18 PM   #1
BlackedOut67shorty
BlackedOut67shorty's Avatar
Question Need ideas for a custom manual throttle
Hey i have a 1967 short fleet that was completly bone stock. I just got a gauge cluster to replace the standard and it has a hole for manual throttle. Id like to use it but i dont have the stock cable and like i said, the truck was bone stock, so i was thinking mounting it on the carb but id like it to look stock. any sugestions or better ideas would help out alot
BlackedOut67shorty is offline   Reply With Quote
Old 08-07-2012, 07:23 PM   #2
67c10rustbuket
67c10rustbuket's Avatar
Re: Need ideas for a custom manual throttle
I think that would be a choke cable, on the upper right corner of the cluster. I have one from my truck around here somewhere. I'm sure you could find one in the classifieds here too, pretty cheap.
Oh, and Welcome to the forum!
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 08-09-2012, 07:22 AM   #3
Steve Hafner
Steve Hafner's Avatar
The manual throttle on a 67 would be on the lower right side of the four knobs, shown below.
Steve Hafner is offline   Reply With Quote
Old 08-09-2012, 10:58 AM   #4
cdowns
cdowns's Avatar
you can install the cable and hook it up to a wolf whistel or a train horn
Old 08-09-2012, 11:13 AM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Not sure if you are aware of it but you can't just swap the gauge clusters without rewiring the electrical plug that plugs into the back of the cluster. You may fry some of the gauges if you do. There is a how to at this link. Scroll down a ways....
http://www.gmcpauls.com/Tech%2520Tips1.htm
LockDoc
Leon
Old 08-09-2012, 01:41 PM   #6
BlackedOut67shorty
Thanks LockDoc,, i knew that i would have to do something like that but wasnt really sure how to convert the wireing so thank you for the link
That be pretty cool to hook it up to a train horn cdowns:headbang:
Unfortunatly i have a 69-70 dash so my wiper switch is gonna be all the way to the right side, guess if i still use a manual choke i could just use it for that but then it wouldnt really have thaat wierd option anymore. Thanks for all these ideas guys
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
Old 08-09-2012, 01:48 PM   #7
Steve Hafner
If you have a 70 dash, you can put it under the headlight switch like mine.
Old 08-09-2012, 01:49 PM   #8
SS Tim
SS Tim's Avatar
Its not a wierd option, it is a truck option. Hope to find a truck with a manual throttle if not I will be adding one to work with a hydraulic or pto winch. Either you need one or you don't and most people didn't hence the relative rarity.
SS Tim is offline   Reply With Quote
Old 08-09-2012, 02:04 PM   #9
BlackedOut67shorty
Never said it was a rare option.I thought it would probrolly help out alot in the winter to get the truck warmed up faster without me having to be inside. I just thought it was a wierd option cause i havent seen alot of trucks with it, but dontget me wrong there probrolly more out there than what i know. I found this dash in a dump truck c30 in a junkyard. Id check around with all the heavy duty trucks like dump trucks and wreckers(maybe even the c50s and 60s if you dont mind using a dremmel) I didnt see alot of c10 or 20s with it but i know that it was an option for them too, not only the big trucks. Just not too often you see them on half tons.
1995 s10 blazer 4.3
2000 mercury sable
Thats a how I roll
Old 09-18-2012, 08:55 PM   #10
BlackedOut67shorty
Still trying to figure out a way to mount the throttle cable without having it bind up on the throttle itself? would it be better to try to make the brackets or should i not worry about it binding up?
1995 s10 blazer 4.3
2000 mercury sable
Thats a how I roll
Old 09-19-2012, 04:27 PM   #11
brad_man_72
the boat guy
brad_man_72's Avatar
My manual throttle hooks to the pedal linkage right in front of the firewall.... still works with my ls swap.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 09-19-2012, 04:33 PM   #12
BlackedOut67shorty
Can you get some pics
1995 s10 blazer 4.3
2000 mercury sable
Thats a how I roll
