08-07-2012, 02:21 PM | #1 |
Grinding Starter
The last couple times I started up my 53 pickup the starter would make a grinding nose. After a time or two of touching the floor starter it finally starts normally. I'm assuming it's a result of using the stock 6v starter and I recently did the 12v conversion.
Any suggenstions on solving? |
08-07-2012, 02:43 PM | #2 |
Re: Grinding Starter
12VDC to a 6Vdc starter "should" just spinn it faster, does the battery have a GOOD charge?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
08-07-2012, 06:13 PM | #3 |
It could be bad bushings, a starter drive going out or some bad teeth on the gear on the flywheel. At least that is where I'd look first.
08-07-2012, 09:32 PM | #4 |
I converted mine to 12 volt 12 years ago and the only "problem" that I've had is that I've had to rebuild (new brushes) the starter twice so far. Granted, this old truck is hard to start sometimes, it sometimes has to spin longer before it starts.
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made |
