Column Shift Question for LSx engine install
Is anyone using a column shift on their LSx engine install? I don't know if I read it here or somewhere else, but they said the column linkage to the trans wouldn't fit because the motors are wider.
Plan is to get an Ididit column and I would really like to have the column shift not a floor shift. Thanks for the help. |
Re: Column Shift Question for LSx engine install
Get their catalog they have cable operated shift levers and call them direct they are more than helpful on install
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
With the shift arm in the standard position (towards the engine) it's WAY too close to the manifold, and I think my vette manifolds tuck better than the rest of the LSx manifolds. I used a Lokar column mounted cable shifter to allow me to spin the shift linkage to the other side of the column. Worked like a charm.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
I too used the lokar cable shift for my LsX conversion and it worked great. I would suggest it. It takes a little bit to get it fine tuned but it is the way to go.
