a/c won't work on high
I've been looking around but can't find a answer to this problem. It's a 84 k10 that when i put the a/c on high it cuts out. I replaced the blower motor relay and blower resisitor and still the same. At the relay i checked with a tester and when i put it on high the orange wire powers up but nothing comes out to the blower...i've already changed it out twice thinking that it was defective....any ideas?
Re: a/c won't work on high
Make sure you have a good ground. will look at the schematic later, but check power to good ground, then at 12v directly to motor to make sure it works good.
Moderator
![]() Join Date: Oct 2008
AC Compressor clutch is not engaging or blower isn't running on high?
If the blower isn't working check the blower relay.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
it's the blower that doesn't work on high. i used a jumper wire from the orange to the purple and it works... what gound are u talking about? is it the one from the blower?
Maybe the switch is bad.
how can i check the switch to see if its bad or not?
believe on the switch..
tan is low lt bl is med dk blu is med 2 ....brn wht high??? Yes the ground on the motor.... where did you jumper? purple and oranage? on the relay? orange and black look to be the coil. on the relay |
i jumped it on the relay
i diconnect the selector switch inside and it still blows on low...is that suppose to happen?
Should be a vacuum line connected to the motor to control some of the ducting and let's the motor go to high for some reason
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
i've checked the vacum lines already.....when i put it on high the relay makes a clik
noise and prevents power to the blower...on the resistor all the connectors have power on high only.. |
there is a switch on the back of the control panel that the a/c. you can get on at classicparts the part number is 68-335 if its not working right the heart will not work right.
#13 |
78K & 79C Jimmys
some are wired for the air to always "flow"
i cut the brown in my 79 to have an off(i have heat only) you may need to replace the motor resistance coil - arrow - prob find one broke
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#14 |
One of these days.......
my 84 crew cab is doing the same thing, high on blower cuts out when i hit a bump. 1,2 & 3 work fine. iv checked the resistor coil and it looks fine, i guess ill put a diffrant swich in the dash an see if that fixes it.
#15 | |
Moderator
Your relay isn't switching volts to the blower with the switch on HI because;
The blower relay is a high amperage SPDT relay that works as follows.
At the relay ORANGE (from the blower switch) and RED should be hot. This is supposed to close the relay contacts between RED (+12v Directly from the firewall junction block) and the PURPLE (blower motor hot).
At the relay RED should be hot. DARK BLUE should have lower than 12v because of the resistors in the circuit. The relay contacts are in the rest position closing the relay contacts between DARK BLUE (blower resistor output wire) and the PURPLE (blower motor hot)Switch positions & Resistor Pak. Note: The volts (less than 12v) at the DARK BLUE wire increase as the number of resistors decreases.
Hope this helps.
#16 |
ok, so i replaced the switch selector, resistor, and the relay...and it's still the same. But, i did notice that i have no power from the red wire at the relay on high...where does that red wire come from?? When you say from the "junction block" do you mean from the fuse box inside?
#17 |
GM had problems back in the day. The blower gets full voltage on high. There used to be a blade connector on the firewall on GM cars and trucks that would burn inside the connector. Trace the wires and look for a connector. I know I repaires these on many cars so I assume that the trucks have them somewhere also. I can look at one of my trucks whel I get home to see if I can find the connector I am referring to.
Frank
Born and proudly residing in a Red State ! |
#18 | |
Moderator
The Junction Block is the main electrical feed block on the firewall in the engine compartment with a stack of red wires on ring terminals. ![]()
And please let us know if and how your repairs were successful. Last edited by hatzie; 08-09-2012 at 04:30 PM. |
#19 |
Thanks guys...it was the connection at the junction block. I just unscrewed and cleaned it up (alot of crusty plastic) and bolt it back up....and now the high selection works..thanks Hatzie.
#20 |
Moderator
Good to hear it was so easy to fix. Stay cool.
