08-08-2012, 08:46 AM | #1 |
Radiator Mounts - pics
I am installing a new radiator and support in my project. I am going with a four row radiator instead of the original three row. The mounting frame and radiator are exact to the old ones, but the new radiator is wider. I ordered new mounts, the bottom fits right, but the top stands up too high as you can see. The mounts are the right width and are for a four row. Do I have the wrong top mounts?
Robert 71 Chevy SWB |
08-08-2012, 09:39 AM | #2 |
Re: Radiator Mounts - pics
Got a close up pic of that bottom mount with the radiator sitting in it? Looks like it's not down all the way for some reason.
Check out my 70 GMC tow truck project here.......http://67-72chevytrucks.com/vboard/s...d.php?t=440431 Member of the 1-Ton Club! http://www.eastcoastcarandtruck.org |
08-08-2012, 01:47 PM | #3 |
I went through this with mine. It's the channel in the rubber insert is not deep enough. I ground down the radiator side channel with a dremel.
08-08-2012, 05:47 PM | #4 |
Just went through this,like mentioned grind them.I took off the whole extruded part on upper and lower for a snug fit.Also had to drill a hole in lower rubber to accodomate new 1/4" machine screw that holds support to core support.
