![]() Join Date: Nov 2010
Front Tire Size
I've been running P275/60/R15s at all four corners on 8 in. Vette rallys and a 4.5 front 4 in drop in rear. Everything has been great! No rubbing or problems at all but....recently I switched to P255/60/R15s on the front because the 275 looked a little big. Now the 55's look too small on the front but if I convert to disc brakes, that will bring the tire & wheel out about an inch to fender lip the P275s would surely rub. I want to keep the 75's on the rear and wonder what would look good on front? Too bad they don't make a P265/60/15.......Any ideas?
Re: Front Tire Size
Perhaps you could keep the 275s but go to a lower profile, like a 40 or 50?
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
Re: Front Tire Size
Thanks for the quick reply...I like the look of a staggered tire combo if they are not too different than ea other. The 55's on the front look great as far as width goes but its failing to fill up the wheel well like the 75's did. We are going to lower the front another inch tonight and see what that does.
![]() Join Date: Oct 2011
Re: Front Tire Size
Sounds like a good idea. I'm running 225/60/15 all the way around on my 66 right now and it looks funny. Thats all I had and cant afford new ones yet.
1960 Chevy Stepside 2wd 1966 Chevy Fleetside 2wd 1965 Chevy Suburban 2wd 1965 Chevy Fleetside 4X4 1960 Chevy Fleetside BBW 2wd |
#5 | |
Re: Front Tire Size
Chris Posted via Mobile Device
1966 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=615165 1968 GTO http://67-72chevytrucks.com/vboard/s...=1#post7650182 |
Re: Front Tire Size
Junior Member
Re: Front Tire Size
Please post some pictures... I've been debating between these 2 sizes recently. Its time for some new rubber and have 275/60r15 on a 8 in truck rally. I have a 2.5 spindle and a 2.5 drop spring in the front so we should be close on the height and bagged in the back.
Thanks Graham
A good friend will come bail you out of jail, but a true friend will be sitting next to you saying, "That was ****ing awesome." |
![]() Join Date: Oct 2009
Re: Front Tire Size
sounds like you kinda like a little wider than stock front tire and a much wider than stock rear. 275 looks too big in front, so you tried same series (60)255 and it looked too small. I'd suggest 255/70/15 (1st & 2nd pics attached for ref), or, perhaps 235/75/15 (3rd & 4th pics) if the 255 is still a little wide for your taste. Both will fill up the wheelwell very well, HOWEVER, I am not certain a 255/70/15 will work with the drop you have. I would assume it would if your 265/60/15 that you originally removed worked.
#9 | |
Re: Front Tire Size
Junior Member
Re: Front Tire Size
So the profile picture is with 255/60r15 and an inch drop??
Re: Front Tire Size
Yes... another inch lower than it was with the 275/60/15s
#12 | |
![]() Quote:
#13 |
Re: Front Tire Size
looks nice,if you switch to drop spindles i wonder if 7'' rims on the front would fit better?dont get me wrong your truck looks great as is i'm just thinkin they might push out quit a bit with discs.
#14 |
Re: Front Tire Size
yes, i agree, those look nice with that amount of drop! Nice choice.
#15 |
Re: Front Tire Size
Here is my 64, 4-6 drop. 275 60 15 rear, 245 60 15 front.
With 15x8 wheels. Have disc brakes too. It doesnt rub at all, could have went with 255 60's on front also. |
#16 |
Re: Front Tire Size
#17 |
Actually I will be ok with the disc....I measured and with the 8" vette rally I still have alot of clearance from tire to fender lip
#18 |
Re: Front Tire Size
just to pass on some measurements i put 15x8's on rear and 15x7's on the front.width measurements from outside edges of rims,rear 72 1/2''.front 72''.
(rear 1/4'' wider on each side...not bad.i'm running 4/6 drop,ece spindles,stock 12 bolt rear end.these rally rims are off the shelf from summit with 4'' backspacing.if i went with 8's on the front it would measure 74''.wider in the front...i no likey.hope the measurements help |
#19 |
Re: Front Tire Size
Here is how she sits now
#20 |
Re: Front Tire Size
The Tonneau Cover fits nice...I did order bows for it
#21 |
Re: Front Tire Size
That looks nice!
#22 |
Re: Front Tire Size
Thanks 62 short step!!!! I've been playing with some door art last couple of nights
#23 |
Re: Front Tire Size
woah now. That turf is taken haha
![]() But seriously, do it. That's the logo I plan on putting on after I paint her. Not period correct, but by far the most well known. I get way more looks and conversations because of the logo than just by the truck itself.
#24 |
Who Me?
Re: Front Tire Size
I would like to run 275/60/15 for my next set of rears. Something a little smaller in the front.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
#25 |
Re: Front Tire Size
