Old 08-08-2012, 01:05 PM   #1
71K20chevy
71K20chevy's Avatar
Mysterious bracket on throttle pedal
Hey all, there's a bracket (which nothing's connected to) mounted to the throttle pedal.
(First picture is the bracket-second is where it bolts on to)
Any idea what it's for?
Thanks!
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 08-08-2012, 01:36 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Mysterious bracket on throttle pedal
Can you post a pic of it attached? It would be easier to determine what it may be used for if no one else has seen one before.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 08-08-2012, 02:20 PM   #3
71K20chevy
71K20chevy's Avatar
Sure...not on right now but it looks challenging to get on I'll get a pic once it's back on. Later today? Tomorrow?
71 K20
64 GMC mud truck
Old 08-08-2012, 03:10 PM   #4
LMREESE
Possibly some sort of after market cruise control set up?
LMREESE is offline   Reply With Quote
Old 08-08-2012, 03:31 PM   #5
davepl
davepl's Avatar
All I can tell you is that I just took apart my truck, every nut and bolt, and didn't come across that piece on my '70 3/4 ton. Perhaps aftermarket cruise?
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-08-2012, 03:45 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Bolt it back on and then take another pic.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-08-2012, 03:51 PM   #7
Wrenchbender Ret
Its for a kickdown switch for a TH400 trans.
Wrenchbender Ret is offline   Reply With Quote
Old 08-08-2012, 04:00 PM   #8
leddzepp
Moderator
leddzepp's Avatar
bingo.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 08-08-2012, 07:01 PM   #9
GASoline71
GASoline71's Avatar
Nevermind!
Gary
Old 08-08-2012, 07:54 PM   #10
68gmsee
Active Member
68gmsee's Avatar
huh? Mounted on the gas pedal? I guess I've never seen anything like that before on the pedal.
06 Trailblazer
Old 08-08-2012, 07:57 PM   #11
leddzepp
Moderator
leddzepp's Avatar
71-72 the kickdown was mounted on the pedal.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 08-08-2012, 08:01 PM   #12
68gmsee
Active Member
68gmsee's Avatar
I was thinking it was attached to the pedal lever itself. It's attached to the hold down bracet.
http://67-72chevytrucks.com/vboard/s...d.php?t=454526
06 Trailblazer
Old 08-08-2012, 09:28 PM   #13
71K20chevy
71K20chevy's Avatar
Guess I don't need it then (my truck has a TH350).
Thanks for the help!
71 K20
64 GMC mud truck
Old 08-09-2012, 07:43 AM   #14
Why would a TH400 kick down switch mount be in a K/20?
Old 08-09-2012, 09:19 AM   #15
68gmsee
Active Member
68gmsee's Avatar
Cab swap?
06 Trailblazer
Old 08-09-2012, 10:12 AM   #16
71K20chevy
71K20chevy's Avatar
Nope, original cab.
71 K20
64 GMC mud truck
Old 08-09-2012, 05:03 PM   #17
BurnoutNova
BurnoutNova's Avatar
It can't be original to the K/20... someone must have added it. They didn't do a th400 4x4 version until like 76ish?
BurnoutNova is offline   Reply With Quote
Old 08-09-2012, 09:25 PM   #18
twich3136
twich3136's Avatar
well that makes sense why i cant get my kickdown switch to work on my 68 longhorn. its a 72 th400 and someone rigged the switch on the old carb.. it doesnt work with my new carb. learn something new every day
USMC
SEMPER FI
68 Chevy Longhorn 350/400 factory posi
twich3136 is offline   Reply With Quote
Old 08-10-2012, 12:26 AM   #19
slim-n-none
I got the exact same one and was wondering what it was. Guess it goes in the pile of parts im taking to the scrap yard when im finally done cause i sure dont need it.
slim-n-none is offline   Reply With Quote
