Old 08-08-2012, 01:13 PM   #1
mlevario99
Exclamation Front Brake Hose with 82 front member swap
Hi, I did the front member swap from a 82 truck into my 66 truck. I install the cpp 2" drop spindles, the quesion I have now is how to run the brake hose, when I try to insall them the hose is rubbing against the bolt form the upper ball joint, the front is not on the truck yet, so I dont know if this is why the hose is against the bolt.
mlevario99 is offline   Reply With Quote
