Old 08-08-2012, 01:28 PM   #1
1774btcrew
1774btcrew's Avatar
Front brakes dragging. HELP!
I have had my 1/2 ton Crewcab short bed done for almost 5 years. When I originally built it I put new calipers on it. My truck has the larger rotors and that is the calipers I supposably purchased(Autozone) . Is it possible they gave me the wrong calipers or could it be another problem? When it was initially done I just figured they would wear in but after 5 years they still drag. I would really like to get this resolved. I am getting 26MPG highway right now but would really like to improve it and I know if I could get the brakes to quit dragging I am sure it would help. Is there a part number cast into the calipers I can check? I appreciate any help.
I guess I should add that I am using the original 3/4 ton Brake Booster and proportioning valve. I bought a complet heavy half ton frame and unbolted the complete front crossmember. Rolled it under mine, cleaned and greased the bearings, turned the rotors and put new calipers on it. That is all.
1774btcrew is offline   Reply With Quote
Old 08-08-2012, 03:04 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Front brakes dragging. HELP!
Calipers are fitted for each rotor and brake size. So you're fine there. Any brake system has drag on it. The pads are always touching the rotor. Now if it's more than just a slight free spin, then you have a problem.
Anybody here would be happy with 26 MPG!!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 08-08-2012, 03:49 PM   #3
1774btcrew
1774btcrew's Avatar
I put the Cummins in if for the mileage but my dad is getting 30-31 Highway with his 94 GMC 4x4 with a 4bt Cummins and 5 speed. I hate him to be getting better mileage than me with a 4x4!
Old 08-08-2012, 04:46 PM   #4
gchemist
gchemist's Avatar
The 4bt is only 3.9 liters. Is yours a 5.9? Huge difference in liter size!!
Old 08-08-2012, 06:17 PM   #5
1774btcrew
1774btcrew's Avatar
It is just the 3.9 Cummins
Old 08-08-2012, 10:27 PM   #6
WarBeard
WarBeard's Avatar
Then it's gotta be aerodynamics, weight, modern axles and tranny?
1978 C10 Silverado Big 10 350/350.. play toy
1990 V1500 Suburban 350/700r4..Daily driver
1987 K10 Silverado 383/400.. Wife's rig WRECKED!
1989 V2500 Suburban 350/400.. SOLD!
1974 C10 Custom10 LWB 350/350.. SOLD!
1974 C10 Custom10 SWB 350/400.. SOLD!
1999 Silverado Z71 LS1.. Wife's rig WRECKED!
On the hunt for a new project.......
I'm a Chevy guy.....I'm just not a "NEW" Chevy guy.
WarBeard is offline   Reply With Quote
Old 08-08-2012, 10:35 PM   #7
1774btcrew
1774btcrew's Avatar
There is actually quite a bit of drag on the wheels. As far as newer components maybe the axles but I am actually running a 4l80e so it shouldn't be that. Could be that he had a manual tranny and I have the automatic though.
Old 08-08-2012, 10:38 PM   #8
WarBeard
WarBeard's Avatar
So you took off the calipers and the rotor spun freely? Could it possibly be wheel bearings?
Old 08-08-2012, 10:41 PM   #9
1774btcrew
1774btcrew's Avatar
Ya, I did check that. I just can't help thinking it is the proportioning valve. But I really just don't know brakes
Old 08-08-2012, 10:44 PM   #10
1774btcrew
1774btcrew's Avatar
I appreciate everyone's input. I am just trying to get a couple bugs worked out of the truck that have been an issue for a while. It needs a torque converter now and just can't bring myself to do it in 115 degree heat so I thought I might fix a couple of the less involved things if at all possible.
Old 08-08-2012, 10:50 PM   #11
Rogue_Alphonse
Rogue_Alphonse's Avatar
It could just be your TC causing all the issue if it needs replaced. Also your gearing... your pop's truck might have a more efficient ratio setup, especially considering it's newer.
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc.
1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980.
1998 Jeep Grand Cherokee 4.0 fully loaded daily driver!
Where there's a will, there's a rig!
Rogue_Alphonse is offline   Reply With Quote
Old 08-08-2012, 10:53 PM   #12
WarBeard
WarBeard's Avatar
Lived in Mesa all my life. I know that heat!
Old 08-08-2012, 10:59 PM   #13
1774btcrew
1774btcrew's Avatar
The Phoenix area is an oven in the summer! I have been here since 83. Ready to live somewhere cooler where working on my truck doesn't cook my brains!
Old 08-08-2012, 11:56 PM   #14
raceman6135
Dino burner
raceman6135's Avatar
How old are the front brake flex hoses? It's fairly common that at the end of their life, the inside can collapse, effectively not allowing the brakes to fully release.
raceman6135 is offline   Reply With Quote
Old 08-09-2012, 12:54 AM   #15
1774btcrew
1774btcrew's Avatar
I hadn't even considered the brake lines. I am quite sure they are originals and have been on the truck since 77
Old 08-09-2012, 01:44 AM   #16
jhngardner367
jhngardner367's Avatar
I agree with Raceman6135. Mine did the same thing,and I had to replace both hoses.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect !
I'm busier than a one-legged cat,in a sandbox!
Veteran..and proud !
I can't fix what ain't broke....you want I should break it?
jhngardner367 is offline   Reply With Quote
