Old 08-08-2012, 03:47 PM   #1
WI65gmc
Alternator problem
Im resided the alternator and switched to an internal regulator but the problem is when the truck is turned off the alternator is draining my bettery this issue is driving me crazy! One terminal is wired to the ignition so when the ignition is on the wire is hot... The other terminal is wired directly to the starter can anyone help or make a suggestion??
Also would adding a diode to the wire help?
WI65gmc is offline   Reply With Quote
Old 08-08-2012, 04:06 PM   #2
Wrenchbender Ret
Re: Alternator problem
You probably have a shorted diode in the alt. Take the main wire off the term in back of thealt. touch it to the term. If you get a tiny spark that is the problem.
Wrenchbender Ret is offline   Reply With Quote
Old 08-08-2012, 04:49 PM   #3
forestb
forestb's Avatar
did you get the adapter for 4 wire long skinny plug that plugs into the external regulator
forestb is offline   Reply With Quote
Old 08-09-2012, 07:47 PM   #4
Shorty Cox
If you single wired it, don't worry about it, it will not drain the battery between driving times, unless you let it sit for extending time periods.
But yes, the "field" is hot all the time.
Shorty
Shorty Cox is offline   Reply With Quote
Old 08-10-2012, 02:30 AM   #5
WI65gmc
Thanks I found out the diode is bad and found a 1 wire replacement for 60 bucks online
