Old 08-08-2012, 06:29 PM   #1
RRR18
RRR18's Avatar
Bulb Out?
Didn't get a chance to post this earlier when I was at home so I figured I would while I was at work. Anyways....My right turn signal in the cluster isn't workin. Is that just a burned out bulb? Or something else? Everything else works fine inside and out just no flashy there.
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 08-08-2012, 07:00 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Bulb Out?
Pull it out and check it...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-08-2012, 07:54 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Re: Bulb Out?
If it worked OK in the past I would say the it is probably the bulb. Remove the bulb holder by turning it counter clockwise about 1/4 turn. Stock bulb is #168. If a new bulb doesn't cure it try wiggling the connection plug on the back of the cluster.
LockDoc
Leon
Old 08-08-2012, 08:27 PM   #4
RRR18
RRR18's Avatar
Re: Bulb Out?
'67 BAD IDEA
Ryan
