08-08-2012, 08:44 PM | #1 |
vacuum advance problem
ok i've got this 66 283 two barrel truck with a carburetor that is apparently not original. it's a holly. the truck has never idled when cold (no choke) and i assumed it was the carb and lack of choke. i have to baby it for like fifteen minutes before i can finally put it in drive. i was fiddling with it tonight and found a vacuum advance problem. the vacuum advance seems fine - holds vacuum and all, but when i try to manually advance the distributor body it's REALLY hard to rotate. the truck has sat a lot but the distributor advance is not frozen or any thing. it's just so hard to rotate that it hurts my fingers to do it. the advance weights open apart just fine. any ideas? is there a spring under there that's way too tight? i've got the idle mixture screw on the holly at max idle and it doesn't help a bit.
08-08-2012, 09:04 PM | #2 |
Re: vacuum advance problem
The center shaft which is supposed to rotate a few degrees is probably gummed up with old grease, you can try to soak it down with WD 40, but I`m going to guess it would be easier to pull the distributor and clean it well with a good degreaser, (Berrymen in aerosol cans ) and re-oil it with 30 weight engine oil, a light coat of WD40 on the top advance weights. and reinstall it.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
08-08-2012, 09:06 PM | #3 |
Senior Enthusiast
This may seem like a silly question, but are you sure the distributor clamp/bolt is loose enough to rotate the distributor body. Some of the older two piece wire types need to be backed off quite a bit before the distributor will rotate freely.
Another way to check the vacuum advance is to remove and plug the present vacuum connection, and with the engine running hook of a line from a full manifold vacuum source. The timing marks on the crankshaft should advance smartly.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
08-09-2012, 03:24 PM | #4 |
i'm not trying to turn the whole distributor. i am trying to turn
the mechanism INSIDE the distributor the same way the little arm on the vacuum advance should do when vacuum is applied. it is just super hard to turn. it should rotate counter-clockwise. |
08-09-2012, 04:05 PM | #5 |
The spring for that is built into the vacuum assem. Yes it is hard to turn the advance plate by hand. You need a hand vacuum pump to pull it in to test it or remove the retaining screws.
08-09-2012, 07:43 PM | #6 |
hey thanks for that reply. that makes perfect sense to me.
i will remove the advance assembly and see what i have. maybe different assemblies have different spring tensions. i know when i plug the vacuum line on it the idle speed does NOT increase. |
