Old 08-08-2012, 08:50 PM   #1
Chevyman13
Accelerator pump issues
Hello, I am new to this forum and have a question that I am hoping someone has ran accross before. We have put a new GM crate 350 in a 1970 c10, owner wanted it kept stock, so we rebuilt the carb, cleaned out the manifold and re-used them from the original 307. Works great for about 3 days and then the truck starts bogging down on acceleration unless you very slowly apply gas. We are finding the accelerator pump rubber is swelling up and causing a lack of fuel on accel. We found a company that says this is fairly common with todays ethenol fuel. They had a "Garter spring" equipped pump that was designed to solve this issue. We bought one and sure enough, 3 days later same thing. Any ideas? Anyone have a source for the original style leather puimps? Any help would be appreciated.
Chevyman13 is offline   Reply With Quote
Old 08-08-2012, 09:39 PM   #2
airdale94
airdale94's Avatar
Re: Accelerator pump issues
I think all of them have that spring. Supposedly the ethanol fuel ones are blue rubber. I got a kit for mine from these guys but haven't installed it yet.
Mountain Man
479-639-2022
airdale94 is offline   Reply With Quote
Old 08-08-2012, 10:35 PM   #3
Lee H
Lee H's Avatar
The kit accelerator pumps are generally not ethenal compatible, even though they say they are. You need to order a pump or two from Cliff Ruggles. Google the name and get a good pump.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 08-09-2012, 12:11 AM   #4
Chevyman13
The one I have now with the spring is blue, did not make a difference. Had some with the spring and without, all were blue rubber. I am in California which does I hear, make a difference.
Old 08-09-2012, 12:28 AM   #5
SS Tim
SS Tim's Avatar
http://www.cliffshighperformance.com...machinesforum/
SS Tim is offline   Reply With Quote
Old 08-09-2012, 12:31 AM   #6
aussiejohn
Cliff Ruggles is the man when it comes to Quadrajets. He does stock the correct parts that are ethanol compatible. If yours is a Rochester 2-barrel, I'm still sure that he can help you. Call him.
Regards from Down Under.
aussiejohn
aussiejohn is offline   Reply With Quote
Old 08-09-2012, 01:05 PM   #7
Chevyman13
Thank you for your help, calling Mr. Ruggles now.
