08-08-2012, 09:31 PM | #1 |
Auto trans linkage with tilt column
I am currently installing my steering column and am wondering if anyone could share either the pictures or a link to their build where I can view how others have used a van or a 67-72 chevy truck tilt as I have one of each!
08-09-2012, 01:16 AM | #2 |
Re: Auto trans linkage with tilt column
I used an 82 eldorado tilt. Because I kept the stock brake pedal I had to use a cable shift mechanism, the pedal swings thru the same area the mechanical linkage goes thru. I looked at after market stuff but found I got the same results with a B&M racing shifter cable and transmission bracket. I fabbed the firewall bracket. Look here http://67-72chevytrucks.com/vboard/s...&postcount=134 Later in the thread it was pointed out that I had the tranny lever upside down in that photo.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
08-09-2012, 08:48 AM | #3 |
here is my 54 gmc with a 68 van non tilt column. i made the linkage and trans bracket my self works great.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
08-10-2012, 11:42 AM | #4 |
check out Kugal Komponents, they have a nice linkage kit. Truck guys will need the 'long' link.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
08-10-2012, 08:41 PM | #5 |
there are nice kits out there. only thing is price and all of them i saw were chrome or stainless steel. i wanted something that looked factory and was cheap. i only have $20 invested in my set up + time. i had the heim joints laying around and they are right and left handed threads. i like to fabricate and save money. gmctrucknut!! pm me if you need more info on my steup.
08-11-2012, 12:36 AM | #6 |
I like that method. I have also done it by cutting the heads off grade 8 bolts and drilling holes in the tube then plug welding them. gotta use female joints though.
