Old 08-08-2012, 11:23 PM   #1
Chvyman1975
Chvyman1975's Avatar
Will these work?
I have a 62 With the 10 bolt rear end. I just found 3:36 gears from a 57 hartop. Will the center sections interchange? The gears are from a 10 bolt as well.
Chvyman1975 is offline   Reply With Quote
Old 08-09-2012, 12:17 AM   #2
Captainfab
60-66 Nut
Re: Will these work?
Typically the passenger car rear end parts do not interchange with the truck rear ends. According to the info I am seeing the Eaton HO32 in the truck has a 9.375 diameter ring gear, and the '55-'64 passenger car ring gear is 8.4" in diameter.
Old 08-09-2012, 12:31 AM   #3
Chvyman1975
Thanks Capt. The search continues.
