08-09-2012, 11:58 AM | #1 |
cruise control ideas
Im looking for some inventive ways of putting cruise on a 71 C10. Im gonna be running a take out LS motor and tranny so it will have cruise, but I don't like the big ugly turn signal arm that activates cruise on my van tilt. So I'll be swapping it out for a standard arm. Any ideas for hiding cruise but not making it a pain to use??
Posted via Mobile Device |
08-09-2012, 12:17 PM | #2 |
Overdrive club
Re: cruise control ideas
I bought an audiovox aftermarket cruise that has a switch you put on the dash,pretty happy with it! They are available on ebay!
1971 c-10 1951 3100 chevy 1970 chevy c-30 Sold! |
08-09-2012, 12:28 PM | #3 |
1965 Chevy C10, 2005 4.8L/4l60
If your going with an LS, would you be going DBW or DBC? either one you can contact Ls1nova on ls1tech.com and he can help you with it. also I got a smaller ( van, slide switch) from him and got mine hooked up with his help. I have a DBC ls motor.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-09-2012, 01:19 PM | #4 |
The switch on the arm has an on/off and 2 momentarys with 4 wires. (ignition power in, set, resume, and cruise power out) On my '83 with TPI I made a small box with a 2' harness and 2 toggle switches; a SPST and a SPDT momentary. I got the dash label from a Peterbilt that says on/off on 1 side and set/resume on the other. I put a 4 pin Weatherpack connector on the dash harness. Whenever I want to use it, I just plug it in and lay it on the seat. When not in use it stores in the glovebox and the plug can hide out of sight.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
