08-09-2012, 12:01 PM | #1 |
Noise that i cant find
I am not sure where to put this in the forms. When i'm driving my truck i hit the speed anywhere from 40 to 55 i start to hear this squeal squeak its not constant so i'm thinking it something that is rotating. I can feel it in my shiftier because it is a manual transmission 4 speed. I was thinking that it might be the clutch plate slipping but hesitant on changing it if that's not whats causing the sound. But like i said i'm not 100% sure its the clutch because it still engages when i drive but the clutch pedal seems to be getting a little harder to push in. Any ideas on this sound would be great I know its hard to figure out what it is with out really hearing what it is.
08-09-2012, 12:06 PM | #2 |
Re: Noise that i cant find
maybe the throw out bearing??
87 Suburban R20 (6bt Cummins) 79 Cherokee Chief (454 from Suburban) - both in progress http://lobie4x4.com |
08-09-2012, 01:09 PM | #3 |
If i pull the clutch out and look at the plate what things would i be looking for on the clutch plate if it is worn out? same thing with the throw out bearing?
08-09-2012, 07:40 PM | #4 |
Square
if you pull the clutch out don't look for anything, just replace it. same goes for anything else that easily replaceable while the trans is out.
Squarebody Syndicate |
08-09-2012, 07:54 PM | #5 |
True but i also dont want to spend money on something that is not need and i want to learn on what i am looking at if its bad or not.
08-09-2012, 08:55 PM | #6 |
Robert Olson Transport
when you change a clutch you traditionally change the throw out bearing , cut the flywheel (or replace it) and swap out your pressure plate.. anything less is a half a job.. its kinda like swapping out a timing belt and not replacing the tensioner ( and water pump if under the belt) on a rice car
08-09-2012, 10:58 PM | #7 |
I would say that it is probably the throw out bearing. As for stuff to replace while in there, keeping in mind a budget, just do the clutch and bearing. I have done several vehicles on the cheap and have had no troubles.
That said, on the dually I spare no expense
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
